Ok, I've 9 of these to use as balanced power trafos, design the rest of a good ...
Old 30th March 2008, 06:36 AM   #1
LineArrayNut is offline LineArrayNut  United States
Question Ok, I've 9 of these to use as balanced power trafos, design the rest of a good ...
...conditioner and I'll give the best, most complete suggestions free tubes, 120v to 24 volt trafos, or motor run caps. I'm good on the wiring, that is tie X2 and X3 together and to ground and H1 and H4 together but to nothing else. My max draw at wide open is 7 amps, but every item will get it's own trafo. I check out my OneAC isolation trafos that I tried out to see if they would help w/ my noisy house and they have caps, movs, and ferrite loops, etc. With a clean sheet of paper and plenty of motor run caps to choose from (from 2uF to 80uF), what would you do?
http://maillist.southernhydraulic.co...0-and-or-240V/
Ok, I've 9 of these to use as balanced power trafos, design the rest of a good ...Hide this!Advertise here!
Good places in the UK to buy balanced audio cables? VvvvvV Multi-Way 1 10th August 2005 10:00 PM
Any good but simple Balanced DAC? tomchaoda Digital Source 3 9th May 2004 11:45 PM
Pioneer TS-W304C- anyone have good design for it? and is it good for home sub? XteveX Multi-Way 7 28th April 2004 05:05 AM
Line matching trafos as OPT's, and other cheapskate ideas? Any good? Morse Tubes / Valves 22 23rd April 2003 10:48 AM
Any cheap, but good, CD players with balanced outputs? russbryant Pass Labs 4 3rd November 2002 11:11 PM
Copyright ©1999-2017 diyAudio
