Transformers: How big is TO big?? - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th April 2008, 03:34 PM   #31
danielwritesbac's Avatar
Originally posted by AndrewT
most recommendations for a 100W amplifier fall in the range 100VA to 200VA.
You will find that a middle ground value of 1.5times the maximum output power works well.
Well, I just tried that out. AndrewT is right.
I used TDA7924 shoving pairs of 8 ohm drivers (bit less than 4 ohms sum), a 50vct, 2 amper transformer, 100va, and 9023uF per rail.
Oh, and a very huge heatsink.
It made 100 very pretty watts and a lot of heat.
The 100va was fine.
With a party EQ'ing and some rather incredible concert like sounds. . . the power supply would hold up to the clipping point without a problem.
With a more like textbook-case power supply, th
Old 25th April 2008, 03:59 PM   #32
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by danielwritesbac
I used TDA7924
Maybe due time to read the datasheet of the TDA7294.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 25th April 2008, 05:00 PM   #33
Oh yes, I'm aware that you're not supposed to push them that hard. That [100w] isn't a recommendation. It was a stress test.
They're only $2, so I hope you don't mind if I decide to "play" with one of them. It played nicely and it survived the test.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 25th April 2008, 05:05 PM   #34
I meant the "100 very pretty watts" part in your post, pretty mean or pretty awfull is my guess.
Old 25th April 2008, 05:57 PM   #35
The cause of the 100w was mostly due to a stronger than normal load. Ah, this wasn't the manufacturer's "free and worth exactly that" design in their pdf, though. It was just a test of a new design. Either way, I think its supposed to be run at 50w.
Oh, what did it sound like? Well, that's not really the point during a stress test, but, okay. . . There wasn't any audible distortions. There just wasn't much difference, except louder and the heatsink got warm. It was nice--some form of hifi, but not quite top rank, and that seems like a typical comment about an ST amp. I much prefer the sound of a good BTL Tripath or a little LM1875, although the ST did nicely.
Well, we're on the power supply forum so. . . This TDA7294 had 220uF ceramic compound caps on the amp board instead of 2200uF electrolytic. There's a difference in heat at the heatsink. Does that mean there's a difference in efficiency?
Old 4th September 2010, 09:56 AM   #36
kipman725's Avatar
Send a message via MSN to kipman725
I am sceptical for the need for a transformer VA greater than the maximum output power. Music is often assumed to be 10dB peak to avrage ratio. Therfore the avrage power is only a third of the maximum. What you are attempting to avoid is core saturation which will take a few cycles of operating above the maximum power rating of the transformer and I just don't think this will happen so easily. As for copper losses they should be not important for all sane sized capacitor banks, as the voltage of the capacitor bank sags it's conduction time increases. Personaly I go for about 0.8x max output rating in transfomer VA rating I shall do some maths to verify this assumption later however.
Old 4th September 2010, 12:29 PM   #37
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Core saturation is NOT caused by loading.
In fact, loading reduces Bmax slightly.
Cap input rectifiers have a power factor in the 0.5-0.7 range, or even less when using oversized transformers and capacitors, as many erroneously believe in. Not only does this mean you need a relatively large transformer, it also means you need a bigger power line circuit, very important for large amplifiers (>500W).
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 4th September 2010, 12:35 PM   #38
let's see the modeling and we can then comment more usefully.
If you are assembling a 68W into 8ohm chipamp and intend using a 54.4VA transformer, I would be very surprised to find that amp performance could not be improved, very cheaply, by increasing the transformer VA rating.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 4th September 2010, 01:50 PM   #39
sangram is offline sangram  India
I totally agree. I've seen a pretty big jump in performance going from a 160VA transformer to a 450VA transformer on a 150-watt chip amplifier. Maybe 450VA is overkill and 300VA would have been enough, but I'm not very trusting of transformer ratings in this part of the world....
Old 4th September 2010, 02:30 PM   #40
I am crazy with my 2x LONO 1000va each at 90vct ac ? no sir... I try it with 630va(already 4 time your and industry standard) under same chassis(exactly same voltage 4x 0-45ac),all from plitron No contest here, with 1000va it is magical and effortless, amplifier disapear ! not box at 130 pounds
But will follow AndrewT suggestion for better grounding !
Praudio
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
FS: Transformers alexcd Swap Meet 0 19th November 2008 08:34 PM
WTB : Transformers korben69 Swap Meet 1 27th June 2008 06:05 PM
my first amp (transformers???) fitchmicah Chip Amps 5 7th January 2007 07:26 PM
Back to Back transformers as Isolation transformers mikee55 Chip Amps 2 17th March 2006 11:38 AM
Copyright ©1999-2017 diyAudio
