Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th March 2008, 07:48 PM   #21
HI,
those transformers from the picture seems to look like those from computer power supply .
In fact most of the computer power supply are rated at 450w peak ,and a maximum of 250w .
In that picture are 8 transformers (8x250w=2000w).
sorry for my english
Old 13th March 2008, 07:52 PM   #22
I wont to built my smps with only one transformer and these because i want to minimize the space ....
Old 14th March 2008, 04:52 PM   #23
N-Channel's Avatar
Send a message via AIM to N-Channel
....then you'll need a really big core......
Old 14th March 2008, 10:54 PM   #24
WOW!!! 2.6kW from one toroid!
Are you going to use a really ligh frequency and low primary turn count to make such power?
To get really big toroid cores:
http://www.cwsbytemark.com/prices/corepwr.php
(scroll to bottom)
They have a 5 inch, and also a 4 inch double height core, along with other sizes. Maybe if you use a LOT of THICK coil wire, and a HUGE core, you could make these work.
Old 14th March 2008, 11:17 PM   #25
HI
EWorkshop1708
YES ,for this smps I will use an etd59...here is a picture http://www.metrafo.ro/poza_428044.html
THE core is not very expensive they only cost about 6$ each ,for the imput capacitor bank i will use 4X460uf/420v ,and 4xirf450 these all will cost about 50usd and many else small components ...very cheap .
The only big problem is the pcb.
I'm learning the orcad cadence now ...
Old 16th March 2008, 06:01 PM   #26
4*460µF for input capacitor bank is not enough for such a power (2600W), input voltage ripple will be very large !
in my half bridge project
2*1800µF/200V in series for 25V ripple voltage at the input @700W
Old 16th March 2008, 06:13 PM   #27
Hi ,
Alexclaire
those 2*1800uf/200v will give you just 900uf ...I will have 1840uf at 320v ,and my amplifier has 2000w ,but I will newer use even 1600w.
The smps ,in the worst case will deliver 2000w ...
Old 16th March 2008, 11:31 PM   #28
Hi ,
Alexclaire
Nice!!!
Do you think it's better to run Amplifier from SMPS from Mains AC instead of 60hz transformer? I'm wanting to build one for a sound system because it's all 4 ohm and needs high current. I also don't like AC hum that can come out of the speakers at 60 hz. What kind of PWR transistors do you use at that side of the SMPS? I tried 350V MJL4281/4302 and blew them up.
Old 17th March 2008, 12:00 AM   #29
HI,
you should use transistors with a minimum 450v ...
I hope this week I gonna finish the pcb layout (the school program stops me ) ,and I will post picture with it ,and maybe with the smps.
Old 27th March 2008, 01:32 PM   #30
IF anyone knows something about smps please post here please....
Smps a2005r2003 Power Supplies 19 11th August 2011 06:19 AM
SMPS for B+ from PC PS jkeny Tubes / Valves 1 10th February 2007 07:52 PM
Smps Juani_12-5 Car Audio 8 20th January 2007 09:15 AM
Smps rinox Power Supplies 0 2nd September 2005 10:05 PM
Need help on car SMPS DFI Car Audio 16 18th June 2004 05:59 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
