Help with dual PS noise shunt? - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th March 2008, 08:46 PM   #11
KSTR is offline KSTR  Germany
KSTR's Avatar
First of all, the Wenzel idea is indeed working (I've tried) and it works better the more linear the correcting amplifier is (a single transistor isn't too good). A disadvantage is the increased DC/LF output impedance, one advantage is that it doesn't fiddle with the main regulators feedback loop, which brings us to Tom's ciruit.
While Tom's circuit is for sure worth a closer look and try, I feel somewhat unhappy with the additional loop gain from the opamp, it might get unstable under certain conditions (had that, too, with a related design where I sensed current high-side with a diff-amp and feed back the drop to the GND pin of a 7812).
Personally I prefer the last stage of a psu to be without feedback, a simple cap multiplier that is (and a duplicate in front of the reg, too), these tend to have way more bandwith that feedback'd approaches. And I use the LM3x7 in the lowest gain configuration, that is without the resistor divider, driving the adjust pin with a voltage (from a divider from the output) buffered with an emitter follower. This is essentially a stacking approach.. There is a post by the late Fred Dieckmann in one of the LM317 threads on this. IMO the main trick for a good regulation with LM317/78xx style regs is to load them and to have enough drop accross them -- same for the cap multipliers. The LM317 works really well with 50mA load and a 5V drop.
- Klaus
Old 22nd March 2008, 01:04 AM   #12
cuibono is offline cuibono  United States
cuibono's Avatar
Well fellows, here is my first pass:
I tried to pay some attention to ground routing, but I'm a noob. Similarly, there may be egregious errors in this, so please beware! Anyone want to proof it before I toast one?
Old 22nd March 2008, 01:05 AM   #13
cuibono's Avatar
the layout. Notice the opamp and smd parts on the bottom, so far only a one layer board:
Old 22nd March 2008, 01:07 AM   #14
cuibono's Avatar
and here is the layout again, showing only tracks. There are actually very few ground connections...
I'm happy with it so far. It measures about 2" by 2.5". Some of the caps sizes may need to change, so layout might too. The board is designed to handle currents under 500mA, which should be plenty for preamps.
Old 22nd March 2008, 05:36 PM   #15
KSTR's Avatar
Cuibono,
In the sheet I see no connection for the opamp supplies, while in the board it seems to be connected to the reg's outputs, right?
One safety thing I would add: clamp diodes at the reg's REF (aka "GND") pins (say two antiparallel strings of a few 1N4148 each) to GND, to limit the range the output could ever swing.
Also, I would provide layout option to power the opamp from the inputs (divided down and filtered). And don't forget to load the regs with some 20mA at least (which could be partly had with opamps powered from the outputs and resistivily biased into class A).
@Tom: With which 12V reg model did you actually sim the circuit?
I assume a typical one, with a 1.2V internal reference and an integrated resistor divider, which would be 9:1 in this case. You amplify the noise with a factor of 14.7, so the internal Ref node would see a "overunity" feedback of the noise, a blip of -1mV at the output would give +1.5mV at the internal ref and a following 1.5mV increase of output, only to be damped / divided down by the (unreliable) dynamic output impedance of the reg and that of the output cap ESR.... this is what scares me a bit, looks like negative AC output impedance could happen -- did you do a output impedance sim? And, to start with, is it stable without output cap?
I think I need to sim it (also with various LM3x7 models I found)...
- Klaus
Old 22nd March 2008, 08:00 PM   #16
gootee is offline gootee  United States
Hi Klaus,
I used the LT1086-12 model that is included with LTspice.
I just now tried simming the output impedance, using a current source from the output with 1A 'DC Value' ('bias' current, since supply is positive-only) plus 0.5A 'AC Amplitude', with an AC analysis run, plotting v(out0/i(out). It is about 412 mOhms at low frequencies and drops from that to about 254 mOhms while going from 10 Hz to 10 kHz. Without the output cap, it's only a little different, and only drops to about 342 mOhms, and does that between 10 Hz and 1 kHz.
Transient response still looks 'OK', without the output cap. But I haven't done any rigorous stability analysis.
I am sure that the circuit could be improved, in terms of both performance and stability. (But I have started a new job and don't have much time for anything else, right now.)
The electrolytic capacitors ARE the signal path: http://www.fullnet.com/~tomg/zoom3a_33kuF.jpg
Help with Shunt Regulation and Noise dsavitsk Tubes / Valves 30 24th December 2007 06:11 PM
Squeaky Noise in ARC Dual 75 neddyboy Tubes / Valves 11 6th June 2007 04:58 PM
Low noise dual JFET pair rtarbell Parts 4 17th March 2006 10:11 PM
Low voltage noise dual OP Holger Barske Parts 7 24th May 2004 06:57 AM
Copyright 1999-2017 diyAudio
