Virtual Battery Schematic
Old 29th February 2008, 11:46 PM   #1
jkeny is offline jkeny  Ireland
Banned
Default Virtual Battery Schematic
Has anybody used this type of regulated PS & how good is it? I've searched under "virtual battery" but can't find anything on DIYA. Here's a short description:
The supply is regulated with a Darlington hybrid (an IRF power MOSFET and a Motorola BUX48 power transistor) to implement a virtual battery (the circuit is based on a Technics design). The MOSFET/NPN pair can conduct up to 400V at 15A and will easily handle the surge currents of large power supply capacitors. The BUX48 should be heatsinked to dissipate about 6W.
I'm thinking of it for a lower voltage of up to 50V. Can it be made variable voltage output?
Old 29th February 2008, 11:47 PM   #2
Banned
Here's another version under the name Power Follower from here: http://www.audiodesignguide.com/PowerFollower/
So, this circuit adopt a little capacitor after the bridge (only 3300uF for an amplifier working with 3A bias).
This capacitor is followed by a MOSFET voltage regulator, featuring a very low frequency CR filter (220uF/100Kohm) which is based on the Virtual Battery Operation, invented by Technics (something good can be found in the consumer world, too).
Old 1st March 2008, 08:24 AM   #3
gootee is offline gootee  United States
Hi jkeny,
You might want to do some searches for different types of regulators, such as Jung or Jung-Didden Super Regulator, Sulzer Regulator, Shunt Regulator, and Series Regulator. You might also want to check out this sticky thread in the Solid State forum: "Bob Cordell Interview: Power Supplies", at http://www.diyaudio.com/forums/showt...threadid=90728 .
The electrolytic capacitors ARE the signal path: http://www.fullnet.com/~tomg/zoom3a_33kuF.jpg
Old 1st March 2008, 02:13 PM   #4
wine&dine is offline wine&dine  Austria
Default Re: Virtual Battery Schematic
I wonder why
Seriously, this is not a regulator, it is an active filter. There is no load or line regulation, only some amount of AC reduction.
The second circuit is missing a couple of electron tubes and transformers
--WD
Old 1st March 2008, 02:29 PM   #5
Banned
Are you guys saying that there is no value to this technique other than
Old 1st March 2008, 04:14 PM   #6
the "virtual battery" (what baloney) tracks input voltage as changed by variations in line voltage and load, and takes out some AC. That may be useful under some special circumstances. In the tube days, this was done using a large choke, that's in a way what this circuit simulates.
A proper regulator gives you a known output voltage, low source resistance (as it regulates out changes due to both load and line changes), and better AC filtering, too.
--WD
Virtual Battery SchematicHide this!Advertise here!
Battery Charger for 15V Li-ION Battery Pack ??? Jan Dupont Parts 2 11th April 2009 02:18 PM
Virtual Ground ? Bernhard Solid State 13 4th March 2009 01:57 PM
Battery PS: Virtual ground or single supply? Dominique Power Supplies 2 5th May 2007 11:34 PM
Looking for 9v battery charger schematic Nordic Power Supplies 2 31st August 2006 07:29 AM
Virtual battery operation A'af Solid State 6 16th August 2002 04:25 AM
