PFC inductor advice
PFC inductor advice
Old 8th April 2008, 07:30 PM   #41
luka is offline luka  Slovenia
luka's Avatar
PFC inductor advice
Hi
That is probably because it is pretty simple to understand, but I think I would go for uc, if anything I could get it more easy
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 22nd October 2008, 02:35 PM   #42
jamesrnz is offline jamesrnz  United States
jamesrnz's Avatar
ok
material types. i built a pfc that works pretty well until the current gets up to 2 amps at 320v then i get crazy spikes in current.. well iused the wrong core a ft-240-77 material. oops saturation i think.
i have a 3, 8, and 26, ft-240 cores.
i read that 26 may get to hot at 100khz? i looks as if the inductance and bmax should be ok however?
it is a 320v at 6 amps.........
Old 22nd October 2008, 06:28 PM   #43
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Ya' know, I hear conflicting advice on material type for the PFC inductor. Some say ferrite (like the #77 material), and others say powdered-iron (like the #26 stuff). In my experience of doing DC-DC uppies, #26 powdered-iron cores have, by far, worked the best.
My very first DC-DC uppie got real hot when current draw was anything over a few hundred milliamps. I had used an FT-68-77 for the core, with the correspondingly low number turns. I remembered seeing several cell-phone chargers using the yellow-white (#26) toroids for the main buck inductor, so I decided to try it for my ckt. Lo and Behold!, the current ratings were normal, inductor temp stayed reasonably cool (until saturation current was reached), and life became good.
I would extend this same logic and reasoning to the PFC inductor core material choice.
Steve
Old 22nd October 2008, 06:39 PM   #44
megajocke is offline megajocke  Sweden
megajocke's Avatar
An ungapped ferrite core will have almost no energy storage capability due to the high permeability so that's pretty expected.
Old 18th January 2009, 08:59 AM   #45
Workhorse is offline Workhorse
Workhorse's Avatar
Is there any way to synchronise this IR chip with master clock frequency.....??
My smps is working at around 125khz, i want to sync PFC also.
Old 18th January 2009, 01:43 PM   #46
switchmodepower is offline switchmodepower  United States
Why do you want to syncronize? Active PFCs usually run at 25-35Khz.
Old 18th January 2009, 07:06 PM   #47
MOER is offline MOER  United States
Default PFC cores
We use Micrometals #8 material as suggested by them. #18 works as well but is more expensive. #26 is useless as the core losses are too high. Our PFCs have to supply upwards of 2.4Kw so core selection is critical
The IR1150s cannot be synchronized with anything else, there is no ramp output just a single resistor for frequency selection.
Running PFC at 25-35KHz will mkae the magnetics very large, and we do not have the space. 100KHz seems to be the best compromise between size, $$ and efficiency.
Steve Mantz
Zed Audio Corp.
Old 19th January 2009, 06:49 AM   #48
Workhorse's Avatar
Beat frequency whistling might occur if not synched..........
smps and class-d are already synched thru master clock..........PFC is left
Old 21st January 2009, 03:23 AM   #49
EnvisionAudio is offline EnvisionAudio  United States
EnvisionAudio's Avatar
Default Re: PFC cores
Steve Mantz
Zed Audio Corp.
Steve, if I may ask, where do you get your toroid cores wrapped?
DCX2496/DEQ2496 Car Audio Conversions
www.envisionelec.net
PFC inductor adviceHide this!Advertise here!
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
Inductor advice MMeche Multi-Way 5 15th February 2008 09:47 PM
air core inductor vs. iron core inductor WBS Planars & Exotics 5 7th May 2007 11:02 PM
Need Advice or Options on Inductor coils speedemon Multi-Way 6 20th January 2007 12:01 AM
Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice moving_electron Chip Amps 0 16th February 2005 12:37 AM
