Dual regulators for single rail?
Old 6th February 2008, 01:58 AM   #1
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Default Dual regulators for single rail?
Any comments on the attached schematic? It seems to me that this design would better reject common mode noise in the AC, but I don't know enough to be sure. I don't remember ever seeing such a scheme shown in a schematic, but I don't know if that means it's pointless or if that as parts count go up, a designer will forgo a 3 terminal regulator in favour of discrete components.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of Totò? Umberto Eco
Old 7th February 2008, 02:17 AM   #2
leadbelly's Avatar
Anybody? Bueller? Bueller?
Old 8th February 2008, 03:31 PM   #3
leadbelly's Avatar
Seriously, nobody has a comment or opinion?
Old 8th February 2008, 03:47 PM   #4
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
I think there's no need, the transformer galvanic isolation provides the rejection of common-mode noise from the mains. All you are doing there is doubling the supply impedance and creating twice as much heat, real estate and cost.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 9th February 2008, 12:47 AM   #5
tINY is offline tINY  United States
Common mode noise should be pretty much eliminated by the transformer. For non-CM noise, I don't believe this circuit buys you anything either.
Is there some issue you are trying to solve here?
-tINY
Old 10th February 2008, 09:17 PM   #6
EWorkshop1708 is offline EWorkshop1708  United States
It's a split power supply without using the middle rail as ground.
Maybe it can be used to get a higher voltage with lower voltage regulators?
Old 10th February 2008, 09:22 PM   #7
leadbelly's Avatar
Not an issue, no. I am planning to build a phono preamp with poor PSRR and want the best performance regulator I can get without going to a discrete design.
Old 10th February 2008, 09:28 PM   #8
Did it Himself
Forget using 78xx or 79xx regs then. Check out the low noise applications on the LM317 datasheet.
Dual regulators for single rail?Hide this!Advertise here!
30 Watt Class D IC that uses a single rail Maroc7 Class D 4 28th March 2009 02:24 PM
Using split rail supply for single rail DC DanX Chip Amps 1 15th March 2008 05:18 PM
Dual Rail JLH ('69 variant) Mike L. Solid State 0 26th March 2006 04:08 PM
Gainclone single rail PS question KT Chip Amps 11 30th September 2004 06:47 AM
Good single rail opamps Bricolo Solid State 27 24th January 2003 04:05 PM
