Help with Induction heating for steam
Old 1st February 2008, 10:32 AM   #11
▀art West-VL. is offline ▀art West-VL.  Belgium
▀art West-VL.'s Avatar
Originally posted by Eva
What is the difference?
A cloud is vapor, fog is vapor.
Steam is when the water expands by the heat, in a closed container that would give pressure. vapor does not change the pressure in a container.
Steam is also possible at lower temperatures but then you would have to lower the pressure. High in the mountains you can boil water at about 80░C, from then on it would be steam only because the pressure is lower.
If you can get near vacuum, you can see the water boil at, lets say, 18░C.
It even go's further. (and a bit off topic)
Because the water boils at 18░C, it has to extract the energy from somewhere to keep boiling, the heat of the container or the water itself.
So after a while you get ice, water and vapor all in the same place.
Break in your loudspeakers at 35% RMS power Right-click'save as...'
Brown noise mono 192kbps(hit "repeat")
Old 2nd February 2008, 12:37 PM   #12
thermal runaway is offline thermal runaway  United Kingdom
thermal runaway's Avatar
Originally posted by len_scanlan
Cheers Geoff,
I knew I'd forgotten something - of course steam burns you much more than hot water, its the additional energy to vaporise the water.
Going back to the original post, I don't know if induction heating would be suitable for directly heating water? As far as I know it requires some conductivity in the material being heated. Fresh water would have too high a resistance to get any appreciable heating effect? Salt water maybe... Ovens with induction heating heat the metal pot, not the contents
Len.
My interpretation is that he wants to heat the water thru transfer from an induction heater. So the induction unit gets hot and the water is circulated around it to transfer the heat.
If pressurised steam is required it will need a huge amount of energy to create as not only the water would need to be heated but the mass of the induction unit too !!
Old 2nd February 2008, 12:51 PM   #13
Originally posted by AndrewT
2quarts (4pints) to steam in 30seconds!
What heat flow rate is that? kW or MW?
are we up to the megawatts guesstimate yet?
regards Andrew T.
Old 2nd February 2008, 12:53 PM   #14
Cant be far off !!
Old 2nd February 2008, 12:55 PM   #15
There may be another way.
Preheat the heater assembly to around 200degC or maybe a lot more.
Then, open the water valve and pass the 4pints through the heat exchanger and out comes 5lbs of steam. But it would need to be a massive heat store and possibly copper rather than aluminium.
regards Andrew T.
Old 2nd February 2008, 01:00 PM   #16
Similar technique is used in flash steam model boats !!
Would thermal shock be an issue ?
Old 7th February 2008, 07:35 PM   #17
brookly Johaph is offline brookly Johaph  Argentina
Definitely use a single tube. I would use one with vanes on the inside to maximize surface area between the water and the metal.
Get a copy of Davies & Simpson's Induction Heating Handbook through interlibrary-loan.
See also: Induction Heating
Help with Induction heating for steamHide this!Advertise here!
Induction planars APi Planars & Exotics 12 6th August 2007 06:53 PM
PS choke magnetic induction Klimon Tubes / Valves 3 9th April 2007 09:45 AM
easiest wood to steam bend for horn? Ang Multi-Way 8 27th February 2007 03:47 AM
Thermopile, let extract some electricity from heat without steam jacquesl Everything Else 42 11th February 2007 09:21 AM
Papst Induction Motor. Paul Dimaline Analogue Source 3 20th March 2006 10:24 PM
