#481 | |
Cheers Cobber. |
#482 |
If you have a transformer rated for 2,8 A, use a 2,8 A fuse, if you find one. If you have a transformer rated for 3 A, use a 3 A fuse. Using a smaller fuse than nominal does not hurt, but it does not help either. On the contrary, although it appears strange, transformer secondaries are usually fused with the next higher fuse, e.g. a 3 A transformer would get a 3,15 A fuse, not a 2,5 A.
Why is that so, when we usually always take the next smaller fuse? Because the power rating of a transformer is a guaranteed performance promise. If you use a smaller fuse, the transformer cannot deliver that power, because the fuse will prevent it from doing that. Accordingly transformers are designed to work on the next higher available fuse size. It is quite common to find a recommendation for the primary fuse on the transformer itself. Sometimes you also find it in the datasheet. If the transformer manufacturer does not recommend a primary fuse, you will have to determine it by trial-&-error.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
| Quick question about star grounding | jn2630 | Tubes / Valves | 8 | 21st January 2008 01:31 AM |
| Question about Star Grounding | voivodata | Tubes / Valves | 2 | 20th March 2007 07:46 PM |
| star grounding with a seperate PSu | Rafal | Chip Amps | 6 | 29th October 2006 07:16 AM |
| Star Grounding Questions | LHMAudio | Solid State | 5 | 12th May 2006 04:31 PM |
| Star grounding in PSU | alexl | Power Supplies | 10 | 7th April 2005 08:46 PM |
| Page generated in 0.09077 seconds (75.09% PHP - 24.91% MySQL) with 11 queries |
