understanding star grounding
Old 2nd December 2010, 04:44 PM   #401
Originally Posted by CopperTop View Post
What are your views on RCDs? What if they were built into the cable?
every power distribution ring in this and my last home had it's individual RCCB at the distribution board. Yes, 5 RCCB on 6 power rings.
Except the audio circuit in the lounge. It is breaker protected and uses fused plug tops.
Does that confirm my viewpoint?
regards Andrew T.
Old 2nd December 2010, 05:11 PM   #402
CopperTop is offline CopperTop  United Kingdom
Are you saying that you didn't protect your audio circuit with an RCCB, but instead only installed MCBs..?
Old 2nd December 2010, 05:30 PM   #403
jneutron is offline jneutron  United States
jneutron's Avatar
The purpose of a fuse is to protect the wires.
NEC page 70-83, Article 240.
John
Old 2nd December 2010, 05:45 PM   #404
yes.
regards Andrew T.
Old 2nd December 2010, 06:07 PM   #405
"yes. "
Sometimes I worry that I seem to need really clear explanations of things that others just pick up straight away. Consequently I probably make my posts too long, needlessly attempting to anticipate the reader's questions...
Just to indulge me, what is wrong with using RCDs with audio equipment if you are worried about death by electricity? Isn't an RCD a good last resort, even if you wouldn't want to rely on it?
Admittedly, a plastic RCD costing £10 might tarnish the sound from your solid gold mains plug - but we don't really believe in that stuff do we..?
Old 2nd December 2010, 06:12 PM   #406
My din rail mounted RCCBs cost about £40 each.
I don't want nuisance shutdown of my Audio Power due to detection of excess Earth Leakage.
It's bad enough in rural Borders with mains brown outs and total loss on an almost weekly basis.
Fortunately , this heavy snow fall has not been accompanied by strong winds. No power outs at all this week !
regards Andrew T.
Old 2nd December 2010, 06:52 PM   #407
Ah, I get you. But what is causing your excess earth leakage? I haven't encountered a problem like that for years.
Old 2nd December 2010, 07:28 PM   #408
Default earth leakage current
any parasitic capacitance from Line to Earth + RF filter capacitors from Line to Earth.
Then include any SMPS in TV/Monitor/Tuner/DVDplayer/Freeview box etc.
regards Andrew T.
Old 2nd December 2010, 07:42 PM   #409
But our whole house is covered by an RCD (30mA I think) and in 5 years it has never tripped. Perhaps I should test it..!
Old 2nd December 2010, 08:30 PM   #410
pacificblue is offline pacificblue  Germany
If so, then all that is needed to banish ground loops forever, is to use fully-shrouded connectors with no exposed metal parts. Then the audio circuits can remain fully isolated from the mains. Could it really be so simple?
It could be, if you don't need to use standardized components that don't fulfull that requirement.
cable screens and bonds to phono sockets etc. are of arbitrarily skinny cable with soldered joints of doubtful mechanical strength. I don't think current rating is usually one of the headline specs people look for in a screened cable. Maybe they should.
These components must have their own fuse which has to blow fast enough to avoid damage. Decent designs will comply with that demand.
It seems to me that as long as you earth the box, physically keep the mains section away from the transformer-isolated electronics and, possibly most important of all, ensure that cables are physically restrained from touching anything they shouldn't even if the electrical joint breaks, you will be fine. (We do place a lot of trust in isolating transformers don't we..?)
That is called class II.
Power strips with built-in RCDs are available.
If you think about it, every large metal object has the potential to make a very small area of contact with "live" (caused by a damaged cable, or a pool of water around a trailing mains block etc.) and to then to present a very large, low impedance connection to the next human who touches it. Kitchen sinks and bathroom taps are already protected against unpleasant potentials, but maybe large unearthed metal objects in general should be banned from the home!
Correct. The regulations that force us to connect conductive cases of electrical devices to earth usually refer to external, but neighboring conductive bodies as well.
That is one of its purposes. Regulations require us to tune fuse and wire sizes to each other so that fires are avoided.
They also require us to ensure protection against indirectly touching dangerous voltage which class I devices do by making the fuse blow. In that case the fuse is also there to protect lives.
Another purpose of a fuse is to protect components other than wires according to the designer's choice.
Yes, you should test it on a regular basis. Here in Germany regulations dictate to do that once a month. Not many people know that they have to test it regularly. Those who know, don't do that, because it means to shut off the power resulting in all the inconvenient resetting of clocks, reprogramming of video recorders and such.
If you've always done it like that, then it's probably wrong. (Henry Ford)
understanding star groundingHide this!Advertise here!
Quick question about star grounding jn2630 Tubes / Valves 8 21st January 2008 02:31 AM
Question about Star Grounding voivodata Tubes / Valves 2 20th March 2007 08:46 PM
star grounding with a seperate PSu Rafal Chip Amps 6 29th October 2006 08:16 AM
Star Grounding Questions LHMAudio Solid State 5 12th May 2006 05:31 PM
Star grounding in PSU alexl Power Supplies 10 7th April 2005 09:46 PM
Copyright ©1999-2017 diyAudio
