Go Back   Home > Forums > Amplifiers > Power Supplies
Old 11th May 2008, 10:15 PM   #21
forr is offline forr  France
forr's Avatar
Star grounding is a technique which often helps a lot but it is not per se a concept. And ground loops are not necessarily evil. For example, fig post #4 rarely gives hum if the shields are very close, just as they are in most circumstances when using twin cables with RCA connectors at both ends.
Old 11th May 2008, 10:35 PM   #22
tsz is offline tsz  Sweden
Send a message via ICQ to tsz
In the connection of post #5 the supply currents to channel 2 and 3 combined with the resistance in the ground wires to channel 1 should give rise to (or am I wrong?) a voltage on the inputs 2 and 3 (referred to their grounds). Will this be significant?
Old 12th May 2008, 08:13 AM   #23
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
Originally posted by fluckscapacitor
If this grounding scheme is used, but the power supply is in a separate chassis (6 foot cable between the two), should the break resistor be put in the amplifier or power supply chassis?
here you go
if you do not like break resistor you can use the other kinds of disconnect network or connect the power g to the chassis.
Zang
Old 12th May 2008, 08:24 AM   #24
digi01's Avatar
the start point of #5 is basis on you do not use the other ground bar.you have to connect all ground wires to a reference 0V point(circuit GND).
Zang
Old 12th May 2008, 03:48 PM   #25
all these recent diagrams omit the Safety Earth.
These will completely mislead any newbie and even more experienced builders, into thinking that what is on the diagram is sufficient.
I suggest that all these diagrams that have a dangerous layout, by omitting the Safety Earth, be removed from this thread, before someone gets killed.
regards Andrew T.
Old 12th May 2008, 04:23 PM   #26
gni is offline gni  United States
gni's Avatar
I admit that the diagrams do omit what type of connection there
is to the AC mains.
If each independent power supply is a double insulated switch-mode,
there there would be no connection to earth ground and the case
could be plastic. That is how it would work in the USA where
we use 120VAC mains.
Three prong connection would require special considerations that
AndrewT and others have outlined in many threads. . .probably
save my life and other in the process. . .
Old 12th May 2008, 09:15 PM   #27
gareth is offline gareth  Wales
gareth's Avatar
People really need to understand the diffefrence between Double Insulated (Class 2) equipment and 'Safety Earth' type equipment(Class 3).
The differences are very, very, major and not to be taken lightly. As has been mentioned by others the differences and misinterpretation could kill if not understood.
Electricity kills people. Under the right conditions 30mA or 0.03A is enough to cause defribilation or death.
Gareth
Old 12th May 2008, 10:28 PM   #28
gareth's Avatar
Perhaps another thread could be started that explains the differences??
Gareth
Old 12th May 2008, 10:40 PM   #29
studiot is offline studiot  United Kingdom
The use of an earth lift resistor can indeed be a dangerous practice if carried out inappropriately.
The technique is sometimes used in stage setups to avoid unwanted hum or other interference/coupling.
It has also lead to some unfortunate accidents and even fatalities in these circumstances so its use its best avoided.
However the following is too sweeping a statement
The exposed conductive parts must be permanently connected to the Safety Earth.
You are surely not suggesting that both the tip and ring of a mains adapter jack plug should be earthed? That would short the supply!
Both tip and ring are exposed metal parts that can be grasped by user and are also connected to the circuit.
Any circuit designer will tell you that circuits soon become so complex that avoiding earth loops is impossible.
In fact the old maths question of connecting three supplies to three houses on a flat sheet of paper proves this topologically.
The real trick is to avoid have large (return) currents flowing in the same segment as that used for input grounds.
Old 12th May 2008, 10:54 PM   #30
If the equipment is NOT compliant with the double insulated standard then it must meet that Safety Earth condition.
It is not too sweeping. It's how they are built by competent manufacturers and we as DIYers are expected to meet at least the same safety standards.
If you knowingly don't and someone gets injured/killed or property damaged then the criminal/civil proceedings may push the point home.
regards Andrew T.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Quick question about star grounding jn2630 Tubes / Valves 8 21st January 2008 02:31 AM
Question about Star Grounding voivodata Tubes / Valves 2 20th March 2007 08:46 PM
star grounding with a seperate PSu Rafal Chip Amps 6 29th October 2006 08:16 AM
Star Grounding Questions LHMAudio Solid State 5 12th May 2006 05:31 PM
Star grounding in PSU alexl Power Supplies 10 7th April 2005 09:46 PM
Page generated in 0.09988 seconds (73.29% PHP - 26.71% MySQL) with 11 queries
