| Thread Tools | Search this Thread |
#101 | |
I now prefer to see the signal ground taken from the RCA barrel/ground tag to the main Audio Ground (Star Ground). This seems to be more resistant to inducing hum/buzz than all the other ways I have tried.
regards Andrew T. |
#102 | |||
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#103 | |
The handicap lies in testing. Mains voltage inside the amplifier (or any other equipment) must remain isolated from all metal parts that can be touched without the use of a tool. And it has to remain that way even during and after a defined mechanical impact, which is what DIYers usally cannot guarantee. On the other hand, which DIYer can do the obligatory earth resistance and insulation tests to guarantee the safety of his earthed, self-made equipment? Must work carefully and hope for the best outcome.
#104 | |
#105 |
#106 |
many of the ideas in this thread appear lethal!
I went to a very good seminar by Bill whitlock od Jenson transformers at the AES in London, follow this link for the papers: http://www.jensen-transformers.com/apps_wp.html the second paper for students is good safe information. regards
Anthony C Smith MAES MinstSCE -I think rain is wet so who am I to Judge- |
#107 | |
a) mark them, so you do not use them for anything else. b) be aware that you are curing the symptoms instead of the disease.
#108 |
ok
i have this image i the pot attached corectly to the gnd p.s. sry my bad english |
#109 | |
http://www.aes.org/sections/uk/meetings/a0705.html You will need to have a printed copy of the "2005 Generic Seminar Template" paper in front of you, just to follow along.
Kevin |
#110 | ||
Pacific, would you care to comment?
regards Andrew T. |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Larsham |
| Quick question about star grounding | jn2630 | Tubes / Valves | 8 | 21st January 2008 02:31 AM |
| Question about Star Grounding | voivodata | Tubes / Valves | 2 | 20th March 2007 08:46 PM |
| star grounding with a seperate PSu | Rafal | Chip Amps | 6 | 29th October 2006 08:16 AM |
| Star Grounding Questions | LHMAudio | Solid State | 5 | 12th May 2006 05:31 PM |
| Star grounding in PSU | alexl | Power Supplies | 10 | 7th April 2005 09:46 PM |
| Page generated in 0.09343 seconds (78.32% PHP - 21.68% MySQL) with 11 queries |
