Go Back   Home > Forums > Amplifiers > Power Supplies
Old 16th January 2008, 04:01 PM   #1
Default Standard LM317, can get 50V?
I need a ±45V regulator, but I can't find any "simple" ways of doing it except by using LM317/LM337 HV parts. The problem is that I can't find these anywhere, even Mouser doesn't have them. Anyone knows how I could get 45V off the standard parts?
I found this:
http://www.national.com/ms/LB/LB-47.pdf
The regulator sees a 5V difference, but I don't know how which resistance I should give to R6 and if the circuit is possible to build for the LM337.
Antoine
http://dmsaudio.ca/
Old 16th January 2008, 04:12 PM   #2
It's no problem at all, the voltage limit for 317/337 parts is the difference between input and output. You can use a standard 317/337 to regulate valve supplies if you like.
The key to long life is to protect the regs 'seeing' more than the 37-39v difference they are rated for, which is a risk at turn-on and switch-off. The diagram you link to does this, but an easier way is to 'clamp' the difference voltage. Add a 24v, 3w zener reverse-biased between the input and output pins of each regulator - which will avalanche first and save the regulator. It has no effect when the supply is up and running. You can then calculate the voltage set resistors as you would normally.
Yo must also include both the protection diodes shown in the LM117/317 datasheet, too.
Old 16th January 2008, 05:10 PM   #3
leadbelly's Avatar
Default Re: Standard LM317, can get 50V?
http://search.digikey.com/scripts/Dk...me=LM317HVT-ND
I found this:
To build the Maida regulator from LB-47 would be outrageous overkill for a 45V supply. Personally, I would just use plain LM317 & LM337 and not sweat anything.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 16th January 2008, 06:34 PM   #4
Thanks for the replies!
So this would work?
Antoine
http://dmsaudio.ca/
Old 16th January 2008, 07:31 PM   #5
leadbelly's Avatar
So this would work?
A few issues:
This would only work if your circuit has a significant draw. If you are feeding a few mA with this, the zener will supply the circuit needs and your regulator will be bypassed.
240 ohms is a little high for the out/adj resistor. National always uses 120 on their datasheets.
Why bother to add the input resistor?
If I was building this, I would just throw everything out except 2 resistors and the capacitor.
Old 16th January 2008, 11:27 PM   #6
Yes, but using 240R cuts total dissipation in R2 and R3. The reg itself.really doesn't care what R1 is, it only sets a constant-current through the lower voltage-setting resistor(s).
Adding a smallish cap to ground after R0 will help no end. 0.1-10uF is enough, with R0 this will reduce noise feedthrough and keep input impedance low at the regulator - 317s like <10ohms source impedance.
BTW the ADJ pin averages 50uA leakage current, which x 8K4 means the reg a posted will deiver about [[(1.25/240) * (8K4)] + (50uA * 8k4) + 1.25v] , about 45.5V. Not way off target, but when using large-value voltage set resistors the ADJ pin current can be significant.
Adding 10uF across R2+R3 will significantly improve ripple rejection and lower the output impedance BTW.
Old 17th January 2008, 12:28 AM   #7
leadbelly's Avatar
That's not true. Read what AN-181 says about 5 mA being a typical programming current and 10 mA for commercial applications.
Old 17th January 2008, 12:52 AM   #8
poobah is offline poobah  United States
poobah's Avatar
Interesting discussion...
Might I suggest something?
TL783CKC Digikey 296-10229-5-ND
Double check the part number... that might be a surface mount part.
about 69 cents... will take you up to 125 Volts...
http://focus.ti.com/lit/ds/symlink/tl783.pdf
Oh, and BTW, don't buy them from Joe's Cryo-special Speaker Cable and More. There was a bad batch a few years back. DigiKey will have good ones. Joe will have the bad ones.
Old 17th January 2008, 04:18 AM   #9
I see 240 everywhere, they even recommend it IIRC ;-)
http://www.national.com/ds/LM/LM117.pdf
I bought them already...
What I want to do is to regulate the tube's voltage supply in the JLTi DIY gainclone. I got the amp working over 8 months ago, but there are loads of hum. The only time where the speaker output is hum free is during the few seconds when the amp is running on the capacitors after I switch the power off. I have to run the amp off a single transformer, unlike what the design recommends : one transformer for the tubes and one for the amp.
More filtering = less noise ? (I already bought the resistors, I have to use them somewhere...)
Most likely going to be a free sample if I use it anyways
Do you know if there's a negative voltage version?
Antoine
http://dmsaudio.ca/
Old 17th January 2008, 04:38 AM   #10
leadbelly's Avatar
Whoa there. If you are ready to move onto tube PS regulation, have you already exhausted fixing the hum by troubleshooting the heater wiring and grounding scheme? Those are much more likely sources of hum in a tube circuit.
Lm317 Reg geowhitt Parts 2 30th August 2008 08:39 AM
Lm317 Soa Onvinyl Power Supplies 2 12th February 2008 03:12 PM
Lm317 jlm Power Supplies 9 2nd February 2006 07:31 PM
Vin MAX for LM317 ZERS Digital Source 4 17th January 2005 02:07 PM
LM317 getting hot! DieterD Everything Else 23 9th April 2002 09:57 AM
Copyright ©1999-2013 diyAudio
