+-35v POWER SUPPLY - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th December 2007, 05:00 PM   #1
Send a message via AIM to synthius
Default +-35v POWER SUPPLY
hey guys,
here is my attempt at a +-35V power supply, it is a a mix of a couple different designs i've seen around.
Please critique/offer suggestions!
Old 10th December 2007, 06:29 PM   #2
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
Hi
You could/should add fuse on primary side, replace that resistor with NTC and I think that you don't need 1ohm resistors on output
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 10th December 2007, 06:39 PM   #3
I couldn't find a fuse in pspice but I do have a
4 amp Slow blow fuse on the primary.
what resistor and what is a NTC?
Old 10th December 2007, 06:52 PM   #4
luka's Avatar
what is a NTC?
http://en.wikipedia.org/wiki/Thermistor
And I was talking about R1, this is probably fuse, but do use fast one... What is your trafo power rating?
I FEEL SLOVENIA
Old 10th December 2007, 06:59 PM   #5
oh I see,
R1 is needed in the design to simulate the traffo's internal resistance(schematic is from a PSPICE simulation).
I am in looking into NTC's right now.
I'm using a Avel Y236652 250VA 25V+25V Toroid.
Old 10th December 2007, 07:51 PM   #6
C1 and C3 need to be reversed in polarity.
Old 16th December 2007, 08:32 PM   #7
TNT is offline TNT  Sweden
This is an advice I would strongly follow!
Old 22nd August 2011, 04:01 PM   #8
hey guys could anybody tell me how many amps power supply should i buy for +- 35v and 100 w power output subwoofer amplifier
Old 23rd August 2011, 03:49 PM   #9
Don't try to work out the amps demand.
All the transient demand of the amplifier is met by the smoothing capacitance and the amplifier decoupling.
The transformer only has to be sized to not overheat on "Party" use and to hold a reasonably small range of voltage over a wide operating range.
The easiest method is to adopt a transformer size that is directly related to the maximum power of the amplifier.
A 100W ClassAB amplifier will run well from a 100VA to 200VA transformer.
100VA 35+35Vac transformer is effectively a 1.4Aac transformer.
200VA 35+35Vac transformer is effectively a 2.8Aac transformer.
Two channels running off a common transformer, would work on a transformer from 200VA to 400VA.
However, what does this mean?:
+- 35v
do you have a 100W into 4r0 amplifier that requires +-35Vdc when fully loaded, or +-35Vdc when in the quiescent state, or do you require a 35+35Vac transformer to power a 100W into 8r0 amplifier?
Don't be ambiguous.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd August 2011, 04:12 PM   #10
thank u so much andrew ...this uw dhelp me building ma first amplifier ....
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Copyright 1999-2017 diyAudio
