rewinding secondary on toroid
Old 20th November 2007, 07:14 AM   #1
guitar_joe is offline guitar_joe  Australia
Send a message via MSN to guitar_joe
Default rewinding secondary on toroid
have seen the recent posts
i have plenty of 160va 25+25's
i want to rewind a ht for tube amp and a filament suppy
theres no problems doing that is there?
Old 21st November 2007, 10:21 AM   #2
R.I.P.
Voltage is the problem.
Then there are the logistics of controlling all that wire for the high number of turns required for a B+ supply.
The heater supplies are easy in comparison.
Keep in mind the turn to turn voltage if you start to multi-layer the toroid. Slight damage to the enamel insulation could create a fire hazard.
regards Andrew T.
Old 21st November 2007, 10:02 PM   #3
well im planning to make the secondary 180 volts and use a voltage doubler rectifier for the HT.
Does this sound like a good idea?
Old 21st November 2007, 10:22 PM   #4
R.I.P.
I think I should order the flowers now.
regards Andrew T.
Old 22nd November 2007, 05:29 AM   #5
care to elaborate?
Old 22nd November 2007, 06:25 AM   #6
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
= It's not a good idea
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 55 pcb's in order. 49 paid.
Old 22nd November 2007, 06:33 AM   #7
i do understand the issues, i would like to know how to do it safely though.
I do know that winding a toroid with 10 metres of ecw could lead to cracks in the enamel and that very tough dielectric materials should be used to insulate these layers.
Old 22nd November 2007, 09:16 AM   #8
R.I.P.
and scratches and production flaws. 10m is never going to get anywhere close to 180Vac. More like 100m for a B+ supply.
How do you intend testing the insulation quality after you have rewound it?
BTW,
the flowers were for the funeral.
regards Andrew T.
Old 23rd November 2007, 03:43 AM   #9
SheldonD is offline SheldonD  Canada
Default Re: rewinding secondary on toroid
[I f you have plenty of toroids why not stack them to get your voltage. You do not have to rewind anything 3 x 50V = !50V
or 4x 50 gets you 200. Filament transformers unles you use 25 V tubes.
Sheldon D
Old 23rd November 2007, 10:41 AM   #10
alright so the idea is crazy... unless i have a proper winding machine it's not going to be safe. damn...
btw i could connect two toroidals back to back and get 230vac if i really wanted too. A guy i know in australia makes valve amps by doing that.
anyhoo dun worry bout the flowers... at the rehearsal studio there was a guy using a variac inplace of a transformer in the amp and there were bare live wires hanging out everywhere... give him the flowers.
rewinding secondary on toroidHide this!Advertise here!
Adding Another Secondary to a Toroid SRMcGee Parts 5 17th April 2010 05:22 PM
[ASK] Rewinding toroid transformer casiomax Chip Amps 2 3rd June 2008 01:46 PM
Discovering Toroid Secondary Voltages vdi_nenna Power Supplies 4 12th March 2008 01:08 AM
Pirmary over secondary in a toroid Peter Daniel Parts 7 15th September 2005 01:24 AM
Rewinding a Toroid transformer hifi Parts 8 6th September 2001 12:50 AM
