to convert a 12v dc car adapter to support 19 volts dc
Old 31st October 2007, 04:45 AM   #1
shadiedog87 is offline shadiedog87  United States
Default to convert a 12v dc car adapter to support 19 volts dc
i wanna be able to charge my laptop that requires 19v dc 3.42A and the cigar lighter in the car is only 12v dc any help
Old 31st October 2007, 06:35 AM   #2
send me sum link a lil info sumthin plz
Old 31st October 2007, 08:32 AM   #3
Tweeker is offline Tweeker  United States
Stick an off the shelf inverter in it and use the laptops regular charger?
Be sure your foil hat has a good low impedance ground.
Old 31st October 2007, 09:31 AM   #4
where would i get somthing like that like radio shack?
late
LILMAN
Old 31st October 2007, 11:23 AM   #5
m-tech is offline m-tech  Serbia
You need something like this:
http://www.diyaudio.com/forums/showt...threadid=93310
Old 31st October 2007, 01:40 PM   #6
Truck stops, auto supply houses, Target etc etc has inverters for automotive use. Radio Shack might too.
12VDC-120VAC-laptop adapter 19VDC.
Old 31st October 2007, 07:27 PM   #7
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Shadiedog,
You might want to look over the thread m-tech suggests, it is chock-full of good info in boost converters. I have made many of these 12-19V boost converters for just the same thing you need: laptop power from the cigar lighter. Almost everyone was made with National Semiconductor's LM2587-ADJ SimpleSwitcher IC. This is a boost IC that, in its simplest form, requires an input cap, output cap, diode, inductor, resistor divider, and a feedback compensation network, usually a 2.2kW or 3.3kW resistor in series with 0.33mF or 0.68mF cap. That's all- just a few components, and you have a very robust DC-DC boost converter.
Go to National's website and do a search on "SimpleSwitcher", and see the multitude of choices of chips you have.
Not to dog on tweeker, but this is a DIY forum, and just buying off-the-shelf kind of defeats the purpose.....
Look at post #35 of the thread m-tech posted. This is where things get interesting.
Hope this helps, and let us know what path you want to take- we're here to help.
Steve
to convert a 12v dc car adapter to support 19 volts dcHide this!Advertise here!
dc volts mike dodd Chip Amps 13 10th August 2009 03:45 AM
Parasound HCA 1000A - convert from 110 to 220\240 volts? buncker Solid State 0 27th August 2008 08:58 AM
power transformers 220 volts to 110 volts garydmd Chip Amps 3 7th April 2007 02:52 PM
I need more volts in my car. Dan2 Power Supplies 15 3rd October 2005 06:55 PM
Gainclone is on 120 volts will it be fine at 220 volts? Jimmy154 Chip Amps 7 29th June 2005 12:10 AM
