Transformer - mystery VA - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 3rd September 2007, 12:21 AM   #1
Default Transformer - mystery VA
I bought a pair of surplus transformers custom manufactured by Toroid for a local company. The (custom)part number does not jive with the standard part numbering/ID scheme which would normally indicate primary/secondary configuration, secondary voltage and VA rating.
Hand-written labels on tape identified the units as 20V, 100VA and as they are equipped with single secondaries, I used a pair for my first IGC. Quite impressed with the performance and having a few more chips to play with, I returned to my "dealer" and carried 10 more units home @ $10 ea.
I don't seem to have adequate power resistors on hand to properly test these things, but based on size/weight, I'm guessing that the units are indeed ~200VA.
Weight- ~5 lb
Dims- 1 3/8" x 5"
Does this sound about right to those in the know?
thanks
7/10
Old 3rd September 2007, 12:30 AM   #2
pinkmouse's Avatar
My rough rule of thumb for toroidals is 1 kilo per 100VA, so that looks about right to me. Good deal.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 3rd September 2007, 01:30 AM   #3
Thanks for confirming Pinkmouse!
I weighed them @ 4.5 lbs ea
Having twice the power that I had counted on may well effect my project list...
7/10
Old 4th September 2007, 01:14 PM   #4
Contradictory situation.
The label says 100VA, yet you want it to be 200VA.
I guess you won't know for sure until the fat lady sings.
Writing is good exercize for the texticles!
Old 4th September 2007, 07:20 PM   #5
Yeah, the fat lady is warming up...
The garage sale style labels and the physical dimensions appear to tell two separate stories. No worries though as my next two quickie projects are two channel GainClones which run happily on these trafos. I'll run a load test BEFORE I make any plans requiring more power
7/10
Old 5th September 2007, 05:50 AM   #6
frugal-phile(tm)
planet10's Avatar
The rule of thumb i've heard is 20VA per pound for EI. Toroid is likely a bit higher, so that jives with the labels.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th September 2007, 05:23 PM   #7
I found a size/weight chart on toroids site...
toroid
... seems to jive with PinkMouse's observations.
7/10
Old 5th September 2007, 05:38 PM   #8
if they got the VA wrong, could they also have got the voltage wrong?
Measure the voltage before you connect smoothing caps and/or rectifiers.
Measure the assembled PSU before connecting the amplifiers.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 5th September 2007, 05:58 PM   #9
MJL21193's Avatar
dave
I've got a 300VA EI, it's certainly not 15 Lbs. More like 5 lBs. I've got 50VA EI's that that are less than a pound.
Old 5th September 2007, 06:20 PM   #10
Thanks guys...
I called Toroid but the girl I spoke to couldn't find the specs for this custom part number as it is at least 3 years old. Testing to come.
Andrew,
126 Volt mains yield 23.6VAC(no-load), 30.6 VDC after rectifier/smoothing caps. I've had a pair of these running a 3875 Inverted GC for about 2 weeks. Cool and quiet.
7/10
Mystery RF amp spooney Car Audio 11 25th April 2008 07:14 PM
Power Transformer mystery lead.... skittletata Tubes / Valves 2 3rd April 2008 04:40 AM
My mystery transformer. azira Solid State 4 9th September 2007 07:42 PM
Mystery transformer Ty_Bower Tubes / Valves 2 15th June 2007 01:24 AM
Mystery SE OPT alexmoose Tubes / Valves 4 11th July 2006 02:29 AM
Copyright 1999-2017 diyAudio
