dual transformer power supply - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd September 2007, 10:09 AM   #1
lizgar is offline lizgar  Philippines
Banned
Default dual transformer power supply
Hi... can anybody help me with this power supply? which is much better to use? power supply 1 or power supply 2 schematic? please help me decide regarding this matter tnx....
Old 2nd September 2007, 10:11 AM   #2
Banned
schematic
Old 2nd September 2007, 11:55 AM   #3
longthrow's Avatar
Send a message via MSN to longthrow Send a message via Yahoo to longthrow
my vote goes to ps1...
you'll have to add resistors each across c1-c4 (act as voltage divider;to equalize voltage on each caps,also as a bleeder) & spike eliminator caps on the output..
H V E Audio
Old 2nd September 2007, 04:10 PM   #4
megajocke's Avatar
What is that high voltage for?
ps2 won't guarantee voltage equalization and it draws dc from the transformers when the load is unbalanced. Resistors on ps1 can work if you want to use the 63V caps, but this is even better:
Old 3rd September 2007, 05:43 PM   #5
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I like the schematic proposed by megajocke. Furthermore, if you are planning a high power class AB amplifier, consider class G or class H instead, because your power supply will already provide the voltage taps required and the amount of heat produced and the stress on the output stage will be greatly reduced.
I use to feel like the small child in The Emperor's New Clothes tale
Old 4th September 2007, 01:27 AM   #6
Banned
i have not tried ps1. but i tried ps2. i used it with single transformer. so i am planning to used two transformer... like this.. i have one here clone amplifier... 500watts @ 8ohms. rated supply 100+/- vcc.
Old 4th September 2007, 08:45 AM   #7
longthrow's Avatar
thats a voltage doubler not recommended at high currents..more unstable;the supply output drops more than the ps1 ckt.
H V E Audio
Dual Power Supply.l egelundvej25 Power Supplies 1 11th June 2009 09:13 PM
FS dual 0-20vdc reg power supply $29 homemade Swap Meet 0 9th July 2008 02:29 AM
Dual 0-30V, 0-2A DC Power Supply - UK Zodiac Swap Meet 0 20th April 2008 04:43 PM
Parallel a dual power supply or two power supplies? Thunau Power Supplies 12 16th February 2007 04:21 AM
diy dual lab power supply morpheus82 Power Supplies 25 10th July 2006 12:41 AM
Copyright 1999-2017 diyAudio
