Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th August 2007, 12:36 PM   #11
jacquesl's Avatar
Yea, that crowbar circuit will work fine, I cant seem to locate that link, can you please supply me with it in a post, I've seem one with a zener and transistor once but cant remember where
EDIT: i finaly founded it
its called "Active Power Zener"
http://sound.westhost.com/appnotes/an007.htm
Old 25th August 2007, 01:19 PM   #12
AndrewT is online now AndrewT  Scotland
no, that is a negative version of your positive regulator.
It is a zener with a bit of muscle behind it.
It is called a "crowbar"
When it triggers it shorts the top to bottom of the triac.
That blows the fuse in the supply line, hopefully before anything is damaged.
regards Andrew T.
Old 25th August 2007, 01:39 PM   #13
jacquesl's Avatar
No man, this device filter out all the voltages above the zener and short circuit it, and maybe that will be able to blow the fuse, I don’t want to use a triac, maybe I cant make it like with if the voltage get to high it flips a relay and disconnects the 28v DC from the rest of the system, this function can be useful for my UPS I’m busy building, I want a under power and over power disconnecter
Old 26th August 2007, 05:30 PM   #14
ifrythings's Avatar
The one you posted is a shunt regulator, if you go with that it will "double" regulate your line, theres still no protection and you have to heat sink the other transistor. A crowbar disables the supply in the event of overvoltage.
Check this site out: http://www.kbt-dc-supplies.com/crowbar.php
Best electrolytic caps for high current power supply. CraigBuckingham Pass Labs 10 2nd March 2005 06:54 PM
Links to High Current Regulated Power Supply? lgreen Solid State 1 25th January 2005 12:11 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
High current DC power supply nikogian Solid State 1 26th March 2004 08:03 PM
Page generated in 0.08887 seconds (74.70% PHP - 25.30% MySQL) with 11 queries
