I’m busy with some UPS circuit and I need it to switch a couple of relays on then the power is back. http://www.allaboutcircuits.com/vol_3/chpt_7/5.html ![]() Can I replace the triac with a transistor because I don’t want to let the relays on until the power is down, I basically want a easy method to trigger a couple of relays then the mains is back, currently I’m using a 10volt transformer on a 12v relay and if the mains drop the relay drop very fast, but the transformer is to small for 3 relays and then using 3 relays I hear a buzz sounds because it probably under power, in my circuit I have a regulated power supply and a small crap 10 – 11volt power supply just to do the relay work and the regulated power supply with huge caps is for the timer section and some other components Purpose needed for: 1 ~ 11 volt - no trigger 12 volt - trigger thx |
#2 |
That circuit looks like a very complex diode, not what you need. What you neeed is a comparator, when the line is 1~11V the comparator does nothing, but when it hits 12V its output flips and enables or disables another circuit.
Here's a site with lots of comparator circuits: http://home.cogeco.ca/~rpaisley4/Comparators.html |
#3 |
use 120/240V relays off the line. the line will directly turn them on if its up.
if only it could be used for good, not evil... |
#4 |
Well, I don’t have any 250volt relays around me but it’s a good idea though, I only have 6v and 12v relays
I’ve found something on the net http://www.electronic-circuits-diagr...armsckt2.shtml ![]() In one of my circuits I use a gate, to make a yes a no; it’s in my timer function in my UPS I have a couple of IC’s available that can be used for these purposes: NE555 UA741 LM358 http://www.discovercircuits.com/DJ-C...vaclowvolt.htm ![]() You’re Example:
#5 |
Get a small 250 Volt to 12 Volt transformer to operate the relays that you have.
Kevin |
#6 |
Ok what do you think of my design?
The above is the mains input and then a power failure or voltage error happens it switches off the supply to the main UPS part How its works: High voltage have a higher value resister, and if that led starts to glow then the voltage is wrong Low voltage have a lower value resister and if that led goes out then the voltage is also wrong Normal state is just a medium value resister that will work fine with most voltage variables and with a zener connected to cut over voltages And that last section before its connects to the relay drivers, that’s 2 transistors, it needs to yes signals before the relays closes No.1 will always be yes and the no.2 will also be yes, but if a voltage error happens then that gate before it will powered and then it will switch of the no.2 transistor Normal state is only there to speed up the process incase of the caps powering the bases of certain transistors that might happens |
| Trigger for Amplifier | Lovan | Solid State | 12 | 22nd September 2008 06:43 AM |
| ac adapter for 12v trigger | cbecker33 | Parts | 0 | 15th January 2005 05:45 AM |
| Type of 12V trigger on Amp? | Texaspledge | Solid State | 3 | 17th November 2004 05:19 AM |
| What is a trigger tube used for? | Gunders | Tubes / Valves | 4 | 30th March 2003 01:53 AM |
| Page generated in 0.09127 seconds (77.52% PHP - 22.48% MySQL) with 11 queries |
