paralleling film caps with electrolytic caps - Page 39 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 9th March 2012, 01:43 PM   #381
If there were big resonances AND big spikes in the music to trigger those
resonances, you'd see them.
Bass tones are poor at causing the "ringing" we're looking for, if the ringing
would be at high frequencies. And treble tones are poor at causing base ringing.
To search for high-freq ringing, you need
(1) a sin-sweep generator providing perhaps 1volt peak-peak
or
(2) a fast-edge generator, and a 555 "rectangle wave" IC at 1KHz period
would be fine; the edges of 555 are faster than 1microSecond, thus serving
to stimulate lots of candidate ringing; the fast edges are just like the slap
of a hand on the belly of a fat guy---the belly joshes around and "rings"
and soon stops because of dampening.
or
(3) music with fast edges, such as (your call) high trumpet notes? they don't
sound like pure tones to me, so probably are good waveforms to search for
"ringing".
The lowest resonance/ringing frequency would be two of the 2,200uF in a loop
with some of the wire. In series in the loop, they become 1,100uF. Assume
couple pieces of 4" (0.1meter) wire, which has inductance approximately of
MUo * length of wire in meters, or [ 4*pi*10^-7 ] * (0.1 meter) = 4*pi*10^-8
or 12.6 * 10*-8 ===~~~ 10^-7 Henry.
Since this is a nice round number, we'll assume the total loop inductance is 10^-7.
Resonate freq of 1,000uF (10^-3 Farad) and 10^-7 Henry is 0.159/sqrt(10^-3-7)
or 16KHz.
All other resonances will be higher.
I think you should try some loud high-freq unpure-sine material,
or build up a 555 oscillator running at 10,000Hertz. And use the scope
to check. The OPA627 has good power-supply rejection at 20,000 and lower
http://www.ti.com/lit/ds/symlink/opa627.pdf
Examine the third row of plots in the section "Typical Performance Curves";
depending on how you've got the opamp connected (don't you hate those
weasel words? check out the schematic! and the compensation cap inside)
you should have at least 60dB (1000:1 reduction) and maybe 80db (10,000:1)
at 20,000Hertz. Thus 1milliVolt of rail-ringing would appear as 1 microvolt
between input to opam, to be amplified by whatever gain configuration you
are using (Unity?).
If we aim for damping factor of approx 1, which also approx Q=1,
then Rloss = Z(L at 16KHz) = Z(C at 16KHz). One is easy to remember. Use one.
But...what if Q=5, because Rloss varies with temperature or aging or brand_name
or Vdd? I like a Q=5, because its dampening, once the ringing has been triggered,
is 6dB per cycle. Thus if the initial half-sin wave is 10milliVolts, the following
opposite polarity half-sine will be 10mV * 0.70 ,
and the following same polarity half-sine will be 10mv * 0.7 * 0.7 = 5milliVolts.
I can easily predict how fast a Q=5 resonance will decay, and Q=5 does last
a while, so coloration is possible IF your PowerSupplyRejection is poor.
Back to Q=1. No ringing, thus no sin-response, no coloration, but you may see
the actual music or voice waveforms on the VDD, accurately appearing, if
the caps are small. [ hmmm I hope this does not become "folklore". ]
What Rdampen to use? Rloss = Z(L @ 16KHz) = Z(C @ 16KHz)
== 2*pi*16KHz * 100 nanoHenry = 10^+5 * 10^-8 ==> 10^-3
or
0.001 ohm.
I expect the wiring resistance, the Caps ESR, or the solder!
to provide enough dampening.
Happy listening
tank
Old 10th March 2012, 08:13 AM   #382
Yes, I have previously gone that path trying to use LTSpice to model all possible RLC in the power supply caps and wires. The pictures were never pretty unless I padded resistance here and there. But in reality, I never like the sound of a power supply with padded resistance. Any resistance added creates ripples which are distortions.
I have built more than a few types of line level regulators. So far the best sounding one is Ikoflexer's shunt reg, but it is quite difficult to build. From learning from and tuning the Iko reg, I gained a bit of experience.
Now I want to sell one of the active speakers I previously built. I don't want to build a shunt reg in the active crossover, so this time I built a LM317/337 reg. With all the experience I gained from building the Iko reg, this time the LM317/337 regs seem to work fine, actually, very fine.
Finding no trace of ringing from my limited scope up to 10Mhz, and hearing the very clean sound from the speakers, I am pretty much sure that even if there are resonances above 10MHz, they would be so mild that don't really affect the sound.
I guess keeping the rail and ground paths short, using ground plane or thick wires, is the first step reducing possible resonances. I guess the 3 large 2,200uF has sufficient ESR to form the damping circuit which may reduce the possibility of ringing.
Old 23rd April 2013, 02:18 PM   #383
Default Question on power supply caps
Hello,
Have been adding a 10 or so microfarad film cap slightly before the main supply caps. Reason I am thinking this would be a good thing is that any voltage spikes get taken by the film caps (more reliable and usually a higher voltage rating I've chosen for this reason).
Thinking this would make life easier and perhaps lengthen the life of the electrolytic caps.
Any idea if this idea has any merit or problems??? So far it has not caused any difference in sound quality that I can tell.
Old 23rd April 2013, 02:36 PM   #384
DF96 is offline DF96  England
No merit, unless you have an unusually high resistance/inductance path between the film cap and the main electrolytics.
Minor possible problem: any HF voltage spikes which do make it past the transformer and rectifier will now see a lower impedance path so the HF current could be greater. This means that is it even more important to ensure that the relevant circuit loop has a very small area to reduce inductive coupling into signal circuits - not always easy to do with large PSU components.
If you want a bypass, the right place for it is as close to the amplifier output circuit as possible i.e. as far away from the PSU as possible.
Old 23rd April 2013, 04:22 PM   #385
Elvee is offline Elvee  Belgium
Elvee's Avatar
No merit, just problems.
If you can provide quantitative data about your configuration, I can show you the difference (just a pic of your set-up would already be sufficient to make a rough estimate).
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 23rd April 2013, 05:46 PM   #386
You're probably better off adding RC snubbers to the rectifier, which would reduce a major source of HF noise (ringing on diode cutoff) and also bypass a certain amount of external crud.
Here's a previous discussion:
Fast Recovery rectifier diodes
Old 23rd April 2013, 09:09 PM   #387
Hello,
Thank you for the feedback. As it hasn't made any difference in the sound (that I can tell) and if it doesn't help lengthen the lifespan of the main caps, seems a waste.
Greg
Old 12th September 2014, 02:23 PM   #388
udailey is offline udailey  United States
Tom,
I have two different choices here
I am placing capacitance on my board building something similar to Doug Self's Opamplifier.
He simply put a .1uf PET across the rails on each opamp. Actually he had the .1uf going from the negative of one opamp the the positive of the next. Shortest distance traces I imagine is the reasoning there and easier layout.
So I can do that but was going to use a midsize tantalum and small ceramic OR I can also use power ground so I would have two tantalums and two ceramics. Your work seems really to incorporate ground here but the opamps never touch ground except through the load.
I did see your discussion on the signal passing through the caps.
What do you think is the best option. Ground involved or rail to rail with opamps?
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 12th September 2014, 03:37 PM   #389
This board I am laying out is only the output section, using NE5532's massively paralleled and all are in non-inverting buffer position so there is no referencing ground.
Old 12th September 2014, 03:52 PM   #390
Found some likely good information. Maybe you can confirm and if its not already been discussed in this thread this is a nice read. The 6th, last, installment of this article series is more to the point but all 6 are good information that help develop a skeptical view of opamp datasheets, models and extremely low ESR ceramics.
Yet More On Decoupling, Part 6: Simulating the complete op amp/power supply circuit
Yet More On Decoupling, Part 6: Simulating the complete op amp/power supply circuit | EE Times
Here are the takeaways the authors present at the end of the article that I thought were most relevant to this thread:
Don't use low-ESR regulator capacitors just because the regulator vendor says they are OK for 'stability'. Your system performance is likely to be significantly better with the additional losses that tantalum capacitors can provide in this role.
A bit of slew-rate limiting in the op amp isn't necessarily bad; the resonances on the supplies are excited less strongly the slower the amplifier output is slewing. But if there are some fast-slewing, wide-bandwidth amplifiers affecting the supply rails, then low-bandwidth amplifiers, with their consequently poor supply rejection, will be particularly sensitive to the resulting noise. Careful in a mixed system!
Use the highest value local ceramic decouplers you can get, in the largest package that will fit, and don't use Y5V dielectric material unless you've fully allowed for the value change with bias voltage. But the volumetric advantage of the high-k dielectric may be completely lost with this allowance.
Adding another small ceramic capacitor in parallel with the main decoupler has a small effect on the amplifier output " but it's often a negative one, so test carefully; most times, it may be unnecessary.
Does someone know these electrolytic caps? 12 Cents Parts 4 25th November 2005 09:26 AM
Paralleling small value caps with large value PS caps xyrium Power Supplies 16 14th October 2005 04:06 PM
Electrolytic Caps jhead Parts 0 21st April 2004 10:11 PM
More Electrolytic Caps MRehorst Swap Meet 3 26th December 2002 10:56 PM
FILM Caps to assist Big ELYT Caps gromanswe Parts 0 9th July 2002 08:16 AM
Copyright ©1999-2017 diyAudio
