Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th November 2011, 02:45 AM   #201
cbdb is offline cbdb  Canada
metre is internationally recognised.
Circuit is a common term to both languages.
Nothing to do with Amercanisation of the english language.
Actually Americans do spell it meter, they dont care what the rest of the world does.
Being psuedo Brits but living so close to the States we Canadians see this stuff all the
time. Litre liter, colour color, pasta pawsta, okay that last ones a joke.
Old 19th November 2011, 03:10 AM   #202
gootee is offline gootee  United States
Originally Posted by marce View Post
Gootee,
read what I said, last sentence...
You cannot design a power supply by ears alone, that is what my point was, I am quite aware of the problems with power supplies...and as I've stated before, the power supply isw the MOST important part of any electronics design, get it right and the rest will go OK, get it wrong and nothing else is gonna work.
BUT when designing a PSU you need to look at the output with a scope, is the rf present, whhat ripple is there etc etc
You cannot hear DC, that is a fact, you can hear noise intereference etc iterposed on the DC but DC is silent, clean and wonderfully unobtainable, even using a battery cannot guarantee noise free DC, so PSU's are designed to WORK in the equipement they are designed for, if they dont as I said before its a BAD design.
My pet peeve is people designing power supplies with their ears...
Again with Andrew, signal has a return path
marce,
I believe that we almost fully agree on every aspect that you mentioned. And also, I did not intend to sound like I was "railing" at you. I am sorry.
You are correct that we cannot hear DC. But again, "DC" refers only to the VOLTAGE rails of the PSU. The CURRENT output from the PSU is _NOT_ DC, when there is music power being supplied through a power amplifier by the power supply.
This thread started (I thought, anyway) in order to discuss paralleling capacitors in a power supply, presumably a power supply that would be meant to supply power for the production of music through loudspeakers.
Since the power supply must supply the dynamic current that IS, usually extremely directly, the music signal which drives the loudspeakers, it seems to me that we are right on target in discussing parallel capacitors in the power supply, along with any parallel capacitors that are used to bypass/decouple the high-power current-control valves that are controlled by the input signal chain, such as the final power transistors or the output stages of chipamps or whatever is used in the output section of the "power amplifier". I often like to think of the bypass/decoupling caps as a sort-of local "point of load" power supply, anyway.
The possibilities for high-frequency resonances being formed between smaller capacitors and the parasitic inductance of larger co-located capacitors, or with the stray or parasitic inductance of attached wires or PCB traces, have been fairly-adequately discussed, already, in this thread.
I think that at least AndrewT and I are interested in understanding more about which capacitors supply which time and frequency components of the music signal current, and how to try to ensure that their implementation has been optimized for the most-faithful reproduction of the music.
My primary goal for an audio system is the most-faithful reproduction of the input, so that the output from the speakers is as close as possible to what was intended by the makers of the source material.
My two main questions related to this thread's topic seem to be:
In terms of the PSU and all of the capacitors upstream from the power pins of the output stage power devices (at least), what and how significant can their effects on the faithfulness of the music reproduction be, and, how would one best attempt to ensure that the cause of any flaw in the faithfulness of the music reproduction would not originate there?
Tom
Old 19th November 2011, 03:28 AM   #203
Originally Posted by cbdb View Post
NO the SIGNAL is actualy voltage. An amp is a voltage device, x volts in gives y volts out regardless of the frequency or load. And y volts out no matter what the current draw.
Try feeding your speakers with a 100ma sine wave and sweep the freq, you will not get a constant SPL output like you should from a 100mv sine wave.
Oh come on! We're saying exactly the same thing. The rest is just semantical (more or less). Voltages just appear between two places. But current is the juice that actually goes through the load and does the work (yes, because of the voltage). Think about it some more.
Either way works, to think about it, but it's actually always both ways at the same time, as I'm sure you know. But in the context of this thread's discussion, it doesn't seem as useful to think about the VOLTAGE on the PSU rails, since that's almost static. In the PSU, the CURRENT is where the action is, especially as it relates to the functioning of the capacitors in supplying the music current that is pushed and pulled through the load (yes, by the voltage; or is it the other way around? <grin>).
Old 19th November 2011, 03:51 AM   #204
[QUOTE=cbdb;2787206][QUOTE]So yes, every component in the power supply is in the main sound-signal path, and could possibly affect the sound quality even more-directly than the components in the input "signal path".
Except for the huge isolation between PS rails and output provided by the OP semiconductors. Your view of the PS rejection is wrong, the output current is proportional to output voltage and thus the error in OP current with rail voltage change is determined by the PSRR.Otherwise that 5 volt ripple on the supply voltage would be deafening.
AGAIN, you are thinking ONLY in terms of VOLTAGE. There is the opposite of isolation of the CURRENT, by the semiconductors, between the PSU rails and the load. The semiconductors are opening and closing their channels precisely in order to modulate the flow of current through them, on its way to the load. They FLOOD the load with always-changing current!
(The following rant is NOT directed at you.)
Why is it seemingly so difficult for so many people to think in terms of PSU output current? Why this fixation on a voltage-centric view of everything? Yes, keeping the power rails at a fixed DC voltage can be very important. But (in my mind, at least) that's not what this discussion is about!
Where do you people think that the current comes from, for the speakers? Does it come in through the signal input connectors? Does amplifying the input voltage magically make current appear from somewhere else? Or do the speakers only need VOLTAGE, alone? No!! Whether your final power amplification components are BJTs and current-controlled or FETs and voltage-controlled, their OTHER two terminals are small-signal-controlled higher-power-capable CURRENT VALVES that enable more or less CURRENT to flow through them, depending on the voltage across them and the control input level. THAT'S just what they DO. They are basically just like small-signal-controlled RESISTORS.
Or maybe I should have just said, "Can we talk about the current, for a little while, and not so much about the voltage?".
Old 19th November 2011, 08:09 AM   #205
AmpliFire's Avatar
[QUOTE=gootee;2787246][QUOTE=cbdb;2787206]
Hi gootee,
Finally, somebody who says it clearly. In fact, power supply buffer capacitors are (merely) to be considered current sources. Otherwise, when thinking in voltage, how who it be possible the feed 2 (or more) channels from a single power supply without crosstalk?
The big 'thinking' problem is that merely all text books / reference documents draw the power supply and amplifier circuits separately (without speakers), noting rail voltage as the unit to focus on, while the reality drawing should be a closed circuit schematic of power supply caps + OPS BJT/FET + speaker. Even better: draw up to schematic like this with both channels. This would demonstrate very well your current view story.
And, it would make an explanation and calculation of damping factor much more 'visible' and understandable as well (but that's off-topic).
Old 19th November 2011, 11:41 AM   #206
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by AmpliFire View Post
just what is the relevance of this test to audio equipment? The pics may look nice, but relevant?
Superficially, that looks like plain common sense.
But in fact, it is a very naive and limited view of the problems involved.
Nowadays, audio gear consists of high speed DACs and ADCs, dsp cores, SMPS's, class D amplifiers, etc, with simple analog baseband applications being the minority.
Even simple analog sources like FM tuners handle base frequencies in the tens of MHz range.
Even when dealing with 20KHz- signals is the behavior at higher frequencies still relevant.
Try to feed an audio amplifier through an LCL lowpass filter of 20KHz, you will see the problem.
High speed, high performance amplifiers require a low supply impedance in the MHz range, or more.
Anyway, this thread is about the paralleling of small caps with big caps, and the supposed improvement it is supposed to bring, and in this case, nothing much happens below 1MHz.
Also, large power caps behave much worse below 20 kHz than the small caps tested in the above test, like I measured in this thread. There is much more to caps then only impedance, such as knowing the capacitor's own resonance frequency (where its ESR and impedance equals), before adding a bypass (or not, that I leave in the middle).
In absolute terms, a 1nF polypropylene cap is always better than a 1,000µF e-lytic, and that is valid at any frequency: the 90° angle between voltage and current will always be better respected with the PP.
The ESL too will be smaller.
Does this make the 1nF a better decoupling cap at 20Hz?
Of course not. The important thing, for the circuit to be bypassed is the module of the impedance, and this includes all the parameters of the complex impedance at that frequency.
Also note that DF values <0 have no physical sense.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 19th November 2011, 11:49 AM   #207
KatieandDad's Avatar
I often wonder if this is complete hype.
My Pass Aleph 4 uses 3 x 33000uF caps per rail per amp, ie 12 in total and there are no smaller bypass caps.
It sounds musically BEAUTIFUL. I wouldn't want to change the sound.
Old 19th November 2011, 02:42 PM   #208
AmpliFire's Avatar
Elvee,
As you point out very well, I forgot to mention relevant 'to regular analogue amplifier', as to put my question in the proper context. Indeed, it is very relevant for class D and digital audio gear, albeit I would not exclude anything below 300 kHz either as done in that test (and imposed by his meter).
You are propably very knowledgable and much more advanced than many people out her, but nevertheless no need to call other forum members 'very naive and limited view' who just try to understand and learn.
Thanks.
Old 19th November 2011, 06:45 PM   #209
Originally Posted by gootee View Post
marce,
A minor correction or clarification:
Of course each PSU rail's curent is also "DC", since there is only a single polarity on each rail. What I meant was that it's not a fixed value of DC. When many people say "DC", they are also assuming a fixed value of DC, and I fell into the same trap.
We can't hear FIXED-value DC but we can certainly hear dynamically-changing DC, as we do every time we hear a "push-pull" amplifier.
Tom
Old 19th November 2011, 11:20 PM   #210
OK, I just ran some simulations with LTSpice, using a schematic/model that I had built up five or six years ago, with a linear regulated power supply and an OP541E chipamp model (inside the feedback loop of an AD845j opamp, in this case), including a lot of the parasitics and strays of both the components and the conductors, and a lumped-component model of the speaker cables, plus lumped-component models for crossovers and speakers. I had a square wave as input (with controlled slopes for the rising and falling edges).
It's easy to see the current from the power rail not quite be able to keep up with the current drawn by the chipamp power pins, and watch as the bypass caps send out exponential-shaped current pulses to make up the difference that's needed, mostly for the transient responses. A 2.5 microsecond lag from the power rail when needing to go from 0 to over 5 Amps in 6 or 7 us means that the bypass caps have to very quickly supply several amps, for a short time, in order to keep the square wave edge linear and prevent undershoot and overshoot (keeping the "corners" sharp).
It's also easy to sum the currents of the PSU's flter caps and compare the total to the regulator input current and see that almost all of the current comes from the caps (the difference was only about 10-15 mA out of 5-6 A).
It was also easy to see severe high-frequency ringing when I added some very small film caps in parallel with the 2200 uF electrolytic bypass caps at the chip's power pins.
I'm interested in how different sizes and types of bypass caps can handle the demands for transient currents. At first I thought that fast transients would need small-value caps. But why would that be true? If it is true, would it be only because their ESR and ESL are usually able to be lower? I know that smaller caps can be fully-recharged faster. So maybe size would matter, then, for fast repetition rates. But considering a one-shot event, how would the capacitance value, itself, affect the initial rate (amps per second, say) of a capacitor's transient current response? Oh well, I guess I should also consider the external series resistance. But that would be very (relatively) low, roughly just the speaker impedance, when a large fast transient is demanded. I'll have to review the basic equations and circuits that used to be so familiar (and try it out in simulations). It's been too many years. But I'm out of time for now.
Does someone know these electrolytic caps? 12 Cents Parts 4 25th November 2005 09:26 AM
Paralleling small value caps with large value PS caps xyrium Power Supplies 16 14th October 2005 04:06 PM
Electrolytic Caps jhead Parts 0 21st April 2004 10:11 PM
More Electrolytic Caps MRehorst Swap Meet 3 26th December 2002 10:56 PM
FILM Caps to assist Big ELYT Caps gromanswe Parts 0 9th July 2002 08:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
