Easy (well not for me) Transformer Question
Old 2nd August 2007, 08:03 PM   #1
Pyre is offline Pyre  Canada
Pyre's Avatar
Send a message via MSN to Pyre
Default Easy (well not for me) Transformer Question
I have a Hammond 160K12 transformer that has dual inputs and secondary's. I have attached the diagram. It is rated to put out 12.6v @ 800ma and 6.3v @1.6A. I am using it for a tube filament supply. How to I wire it to put out the 12.6v? I am assuming that I would connect the 115v to 1 and 4 bridge 2 and 3 on the input side and on the output side I would get 12.6 from 5 and 7 with 6 and 8 bridged. Is there any simple way that I could make it switchable between the 12.6 and 6.3?
Thanks in advance for help on this simple problem
Old 2nd August 2007, 08:13 PM   #2
bikehorn is offline bikehorn  Canada
bikehorn's Avatar
put the primaries in parallel for 115 volt operation, and put the secondaries in series to get 12.6v. You could wire up a series/parallel switch, but unless it's for a test supply i don't think you'd gain much by being able to switch.
Old 2nd August 2007, 08:32 PM   #3
Pyre's Avatar
Thanks I will wire it up as such to get the 12.6 volts. I think I figured out what was confusing me so badly. The diagram that I have showing how to hook it up in parallel or series changes the pin out order in each diagram.
It is for a test supply. I have a couple of different preamps and one takes 6.3 and the other 12.6 for the heaters and instead of changing the jumpers on the 6.3 every time I thought I could make a switch on the supply.
What part of Toronto are you in? I am just down the road in Burlington/Oakville
Thanks!
Old 2nd August 2007, 11:06 PM   #4
bikehorn's Avatar
Well I wouldn't say toronto, I actually live in Woodbridge. toronto's just a reference point for non-ontarians...
Old 5th August 2007, 03:52 AM   #5
head_spaz is offline head_spaz  United States
Hope this helps.
Writing is good exercize for the texticles!
Old 6th August 2007, 01:39 PM   #6
Pyre's Avatar
Thanks so much! Thats exactly what I was looking for.
Easy (well not for me) Transformer QuestionHide this!Advertise here!
Easy question, sorry jhawker23 Car Audio 2 31st December 2007 04:13 PM
Probably an easy question for some. markusb Solid State 1 22nd September 2006 08:29 AM
Probably an easy question... maguire Subwoofers 8 18th September 2006 07:23 PM
easy question iLyO Multi-Way 23 14th November 2005 08:23 PM
stupid but easy question... cowanrg Chip Amps 2 20th July 2003 05:18 AM
Copyright ©1999-2017 diyAudio
