#31 |
Anybody see the error in the schem that draynes linked to?
#32 |
Hi KSTR,
Yes, but it should be a non-issue for this thread. Hi draynes, Only your first two 2N3055's are connected correctly. The rest have a base to collector short, they are fancy forward based diodes. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#33 | |
#34 | |
Yeah, just noticed that myself after looking at it closely. I had gathered up the parts for this thing but had never got around to building it. Oh well, the concept is totally valid for DC testing. At work I've used constant current electronic loads like this for battery testing. One project I got involved in some years back was manufacturing and testing thousands of battery backup supplies used in cell tower installations. The discharge testing phases were all done with transistance loads in order to maintain a constant discharge current. I forget now which Asian company made the electronic loads we used, but they were essential for the job. Resistive loads would not have worked. |
#35 | ||
Hi draynes,
-Chris
#36 |
Active loads with programmable IV characteristics are a standard part of ATE (Automatic Test equipment).
#37 |
Help to find the schema for this load, broke down and there is no scheme please
http://www.pewa.de/DATENBLATT/DBL_BE...TT_DEUTSCH.PDF
#38 |
It all depends on the test duration.
For short time testing glass coated thick and short ceramic body resistors are best. I used 6 peaces of 300W rated 0.5ohm resistors to limit the inrushcurrent of a 250kW 3% regulation 400V 3-phase transformer. The inrush current was in the kA range. The ceramic body has heatcapacity many times higher than metals and is only second to water. I also tried Dale 300W metalcased resistors mounted on a 2 squaremeter! heatsink. But I needed 48 of them and still had reliabilitie issues. One 300W ceramic resistor will be all you ever need for testing audioamps. For longtime testing of big amps powersupplies you may want forced cooling and/or a couple of more resistors. |
#39 |
That replacement speaker for an equivalent load.
#40 |
Please can explain a bit more what exactltly it is to be equivalent to?
| 8 ohm dummy load | andrewe1 | Parts | 43 | 9th May 2011 06:44 AM |
| Tri Dummy Load | raudio1969 | Parts | 0 | 25th February 2009 02:14 AM |
| dummy load | reddish75 | Solid State | 72 | 3rd April 2008 02:15 AM |
| Dummy - load | JensRasmussen | Solid State | 24 | 23rd February 2007 02:04 PM |
| Dummy Load resistors | JOE DIRT® | Parts | 6 | 4th June 2003 03:15 PM |
| Page generated in 0.08623 seconds (71.74% PHP - 28.26% MySQL) with 11 queries |
