#11 |
Hi
Not bad, not bad at all, just price couldn't be low, is it? |
#12 |
Cantenna can use clean engine oil. Mineral oil is better, like baby oil.
Sealing it is actually a very bad idea, it gets hot in use and the lid pops off and makes a mess. I found out the hard way.... A small (1 litre) Cantenna is better, It is much more portable and if you need more power you put it in a bucket, the sink or even the bath. I suggest soldering a thread onto the top of the can with a removable cap to allow it to breathe when in use. For big AC power supplies & UPS I use a 10 amp variac with an electric kettle. For a fixed current load for discharge testing 24V battery packs I made a 7810 voltage regulator feeding a 10 ohm resistor. |
#13 | |
Hi Mike,
-Chris
"Just because you can, doesn't mean you should" © my Wife |
#14 |
Hi
You see. That why I don't wan't anything liquid on my bench, like water or oil Power resistors with forced air seems at this point to be better choise...
#15 |
Hi zeonrider
Have you run your power resistor at some higher power level for any longer period of time, so that it did heat up a lot? I am thinking of using same lab sockets, which are rated around 80-100 degrees. I worrie what if air inside generated by resisotors will be 300, then over time case will heat up to that temp. too, melting plastic. Did you have anything like that in your case, or it doesn't heat up that much? And what is that red thing around sockets? |
#16 |
2 channel 8 ohms (other channel on the hidden side.)
I just use a jumper for 2 or 4 ohms. 2 x 100W for a minute or so is no problem. |
#17 | |
--WD |
#19 | |
Asbestos was used in brake discs once. Mercury was used to "cure" syphilis once. ... and Chlorine was used to kill enemy troops once.
--WD |
#20 |
massdevelopment of chlorine is limited to DC, in case the saltwater is used as AC-load only, there may be small amounts of chlorine escaping the water
if this leads to a dangerous level in a well vented enviroment, is at question. I suppose saltwater is a bad dummy load for amplifiers, because of the large! tempco, the frequency behaviour and whatever. regards |
| 8 ohm dummy load | andrewe1 | Parts | 43 | 9th May 2011 06:44 AM |
| Tri Dummy Load | raudio1969 | Parts | 0 | 25th February 2009 02:14 AM |
| dummy load | reddish75 | Solid State | 72 | 3rd April 2008 02:15 AM |
| Dummy - load | JensRasmussen | Solid State | 24 | 23rd February 2007 02:04 PM |
| Dummy Load resistors | JOE DIRT® | Parts | 6 | 4th June 2003 03:15 PM |
| Page generated in 0.09808 seconds (65.54% PHP - 34.46% MySQL) with 11 queries |
