Constant current source, am I missing anything... Constant current source, am I missing anything... - diyAudio
Old 2nd August 2007, 09:50 AM   #1
gmphadte is offline gmphadte  India
Default Constant current source, am I missing anything...
I want a ccs variable from 1.6 to 1.8A, a little more than a single LM317 can supply. The circuit should be simple and cheap. So I came up with the design shown. I know there are higher current regulators, but they have more disadvantages.
Is it alright or am i missing something?
Nothing to do with audio.
Gajanan Phadte
Old 2nd August 2007, 10:47 AM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
I don't think it will work. The bottom one will be supplying all the additional current when set to the 1.6-1.8 amp range.
Have you considered an op-amp, buffer transistor and current-measuring resistor?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 2nd August 2007, 11:06 AM   #3
The lower IC is supposed to supply the difference.
I will construct and find out.
Gajanan phadte
Old 2nd August 2007, 11:44 AM   #4
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Should work OK. The nice thing with current sources is that you can just connect them in parallel. The Zout of each prevents the other to supply current into the other source. I think your circuit will work as required.
I actually think you don't need the OR-ing diodes.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 3rd August 2007, 04:07 AM   #5
Jan Didden
I tested and it works.
National recommends 0.2 ohms at the output when paralleling the two 317s and mine are over 1.3 ohms. I will try without the OR-ing diodes.
In the final circuit, I will keep the diodes, in any case, for preventing catastrophic results in case one 317 fails.
Gajanan phadte
Constant current source, am I missing anything...Hide this!Advertise here!
Constant Current Source article (Old) tvi Solid State 12 9th June 2012 09:33 PM
constant current source hacknet Solid State 19 13th March 2006 02:46 PM
3 constant current source questions Jef Patat Solid State 12 18th January 2005 02:30 PM
[off-topic] 1A constant current source? MWP Solid State 1 6th November 2004 07:37 AM
Copyright ©1999-2017 diyAudio
