Hello people there. I've just bought the stuff neccesary to assemble two LM1875 split suply and fit a stereo amp. I got evr'ything but the supply.
I guess I need a dual supply, but I have no idea about how to assemble it. I can't find any diagrams of it, and I know that supply is the most important thing to make an amp work. I'll use two 10W speakers, so I guess the source has to be a +20/-20 V, 1A, but nothing else. Has anyone fitted that kind of supply for the LM1875? Can you show me diagrams, datasheets, pictures or whatever? Tank you very much, Alexis. |
#2 |
Here it is:
The image is linked from http://sound.westhost.com/project72.htm , where a LM1875 based amplifier is described. Did you think something like that?
Best regards, Danko |
#3 |
Yes, that's right what I mean, but I can't see any diodes in the diagram, and... why is the fuse bofore the transformer?
The diagram is clear, but, is there any fascimiliar sheet for the printed circiut? Thank you very much. Alexis. |
#4 |
The diodes are in "BR1". That's a diode bridge.
That fuse is there, to protect the transformer and the mains network from overloading, shirt circuit.
#5 |
Ok, thank you. I'll buy all the stuff, assemble and test the supply.
I'll post the evolution of project and future doubts and troubles, and, once I have the full gainclone ready and working, I'll post the experience for those who (as I do now) need some help. |
#6 |
Be careful at the primary side of the transformer! There are lethal voltages, that can kill you in a moment, if you touch at the wrong part!!
Also be areful at the secondary-side. 20-30V is not as dangerous as 230V, but touching a capacitor, charged to 25V could be "surprise". Good luck on the project!
#7 |
Once, I reeplaced a capacitor of my PCs monitor. It was a big one, I do not remember how big, and I touched the burned one with my thongue. It was strong, belive me.
#8 |
The PCB for split provided by National in the datasheet of LM1875 has a mistake, there's a 1000 uF cap with not specified position. Should I put - in the V- track?
The one I'm reffering to is bellow the chip in the picture: http://petrovich.nutus.com.ar/Split ... corregido.jpg Also, I made a new PCB with Photoshop, fited to a 36x36 holes multi-purpose grid. It will be here in next post, availabe for whose don't want to print a special PCB (which can be a little expensive in some countries). Alexis |
#9 |
Electrolytes and Tantalum capacitors have a polarity that should always be respected.
In laymen’s terms: Always connect + to + and – to -. All other capacitors don’t mind how you place them, electrically spoken. /Hugo |
#10 |
a 15Vac + 15Vac 50VA transformer will give about +-20Vdc and sufficient power for two channels with maximum power between 10W and 15W/channel. Use +-10mF on each amplifier's supply rails. Your smoothing caps could be right on the limit @ 25Vdc. I would use 40Vdc to allow for higher than normal mains voltages.
regards Andrew T. |
| Symmetric supply or dual supply? | JWFokker | Parts | 32 | 11th August 2011 09:29 PM |
| Help with first Power Supply for LM1875 | simonlarusso | Chip Amps | 105 | 10th July 2010 01:29 AM |
| printer single supply becoming split supply? | facundonu | Power Supplies | 2 | 16th November 2006 07:09 PM |
| Lm1875, Single Or Dual Supply | alcuemar | Chip Amps | 5 | 24th May 2006 04:02 PM |
| Page generated in 0.10199 seconds (79.73% PHP - 20.27% MySQL) with 11 queries |
