Go Back   Home > Forums > Amplifiers > Power Supplies
Old 6th November 2009, 03:19 AM   #31
danielwritesbac's Avatar
If heatsink has voltage, must use wooden amplifier enclosure.
Even better to do a wooden enclosure and an insulated heatsink.
Its not a good idea to have both a voltage source (heatsink) and a voltage reference (metal enclosure) within the reach of fingers.
For metal enclosure, insulate the back of the chip--use a size TO220 Mica insulator, White thermal compound and shoulder washers.
Any amplifier enclosure needs air inlet at the bottom and air outlet at the top (or top of back panel).
The surface of MDF is flammable. MDF needs finished, like paint, Lacquer, polyurethane, etc. . . You can use brown spray primer, scribble that with a black sharpie (wood grain looking scribbles), and then paint with "Polyshades" of a dark color like Bombay red or Walnut brown, for a fairly pretty finish on MDF.
P.S.
Also observe a common 2-cell flashlight. This is similar to a split rail power supply. The centrepoint between the two batteries in the 2-cell flashlight is the 0v tap.
Symmetric supply or dual supply? JWFokker Parts 32 11th August 2011 08:29 PM
Help with first Power Supply for LM1875 simonlarusso Chip Amps 105 10th July 2010 12:29 AM
printer single supply becoming split supply? facundonu Power Supplies 2 16th November 2006 06:09 PM
Lm1875, Single Or Dual Supply alcuemar Chip Amps 5 24th May 2006 03:02 PM
Page generated in 0.08261 seconds (61.67% PHP - 38.33% MySQL) with 11 queries
