#11 |
Why can't you just disable the full bridge? I don't think that an additional switch is required.
I use to feel like the small child in The Emperor's New Clothes tale |
#13 | |
#14 | |
#15 |
By the time the microcontroller notices the overcurrent caused by a single MOSFET blowing, you will already have a total of three MOSFETs blown with a dead short between drain and source, including the main high side switch...
#16 |
Electrons are yellow and more is better!
TechGuy, a HIP4082 is pretty nice and also safe. I have personal experience of this IC and here we talk 475 A in a pcb!
/Per-Anders (my first name) or P-A as my friends call me |
#17 | ||
1. Multiple Discrete switching frequencies depending on the load. At low loads, the switching frequency is lower and higher frequencies during higher loads to maximum efficiency while using a small transformer core. 2. ZVS switch and possibly micro switching (at low loads). 3. Synchronous Rectification. 4. Thermal monitoring and shutdown 5. Low input voltage detection (and shutdown). 6. Start up self-test. Thanks for your interest |
| High end Switch Mode Power supply for Audio | Petter | Parts | 29 | 5th May 2010 06:42 AM |
| Switch Mode Design.....help? | MotoMan_Yz400 | Chip Amps | 8 | 31st January 2008 01:07 PM |
| Using a spdt switch to select between triode mode and pentode mode on a guitar amp. | G | Tubes / Valves | 19 | 15th March 2006 09:15 AM |
| switch mode | Retsim_X | Power Supplies | 0 | 18th September 2005 11:55 AM |
| Low side driver as a High side | fr0st | Parts | 0 | 8th May 2004 02:14 PM |
| Page generated in 0.10530 seconds (77.00% PHP - 23.00% MySQL) with 11 queries |
