Dedicated PSU for DEQ/DCX2496
Old 23rd April 2008, 04:06 PM   #311
Originally posted by Moby
......... Situation is not so great OPA2134 are really hot, from 65 to 75 Celsius, and AKM DA's are around 65... PSU is 70-75. ............
these must be surface temperatures.
What are the junction temps that create this mess?
regards Andrew T.
Old 24th April 2008, 04:29 AM   #312
Moby is offline Moby
Moby's Avatar
I measured inside the box with open top and then I removed the in/out board and measured the "down under" opa's. I checked the currents at GND's and it seems OK, like you stated... I will check the individual currents and post the result.
Old 24th April 2008, 09:04 AM   #313
artquake is offline artquake
Did i miss something ?
"OPA134 series op amps are capable of driving 600W loads with power supply voltage up to 18V. Internal power dissipation is increased when operating at high supply voltages."
How much is the supply voltage ? +/- 15 V ? or maybe higher ?
In my setup the hottest signal conditioning parts are the DSP Chips. And they are about 40..42C @ surface whiile AKM is about 36C. (When DEQ is set to "linear" EQ-Position and mostly blocks set to bypass. But when using more settings of DEQ then DSP can get up to 45 ... 50C. The more calculation the more heat dissipation In someway logic.
Another Question:
While listening to music, are you using the DEQ in balanced operation ? Or do you use XLR to RCA Adapter while using only the (hot +) wire output ? If so, then you could check also your soldering on OPA's for short circuit @ (- Input legs) That could force also power dissipation on the OPA.
the truth is somewere
Old 24th April 2008, 01:17 PM   #314
Moby's Avatar
Another Question:
PSU voltage is +/- 15V. I tried to lower the voltage and they are still hot BTW I have DCX not DEQ...but op-amp is still op-amp I'm using the unit in balanced mode...
One thing is for sure. Problem is something in general because I tried to completely remove analog board and I connected just +/-15V directly. Opa's are still hot. I checked the outputs with oscilloscope and I can't see any oscillation. Just a noise , at lower voltage setting . (I think that at 5mv) That noise is uniform too at all six outputs.... BTW, unit sounds OK
Old 22nd October 2008, 04:15 AM   #315
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
The PSU in DEQ.
Click the image to open in full size. ''
And it was worth the effort..
Now just have to change that oscillator..
Regards ke
Old 22nd October 2008, 01:00 PM   #316
Moby's Avatar
How it sounds? At the end I removed linear PSU and returned to switching (original PSU). I had the "thump" on-of issue and have an impression that stock psu sounds better
Old 22nd October 2008, 02:14 PM   #317
Ryssen's Avatar
Voices are more upfront and treble more distinct,I think the original psu was more soft and laid back.
Regards ke
Old 23rd October 2008, 06:00 PM   #318
Ryssen's Avatar
Did you change the Oscillator to?
Have anyone else changed the PSU?
Impressions?
Regards ke
Old 23rd October 2008, 08:40 PM   #319
Moby's Avatar
yes, I changed the oscilator op-amps and coupling capacitors. Everything resulted like improovement, especially capacitors. But as I mentioned before I had that on/of nasty thump so i returned back to the stock PSU. Maybe is something faulty with PSU but I bought it completed so I have to investigate. If I remember well noone but me has thump issue... Maybe I'm wrong??
Old 23rd October 2008, 09:17 PM   #320
Ryssen's Avatar
I to get a thump if I start the amlifier before DEQ..
Regards ke
Dedicated PSU for DEQ/DCX2496Hide this!Advertise here!
One box dedicated headamp/preamp. khundude Pass Labs 5 10th June 2008 04:09 AM
a dedicated piezo amp. Pbassred Multi-Way 2 2nd February 2008 04:58 AM
Why FR may sound better with dedicated HF unit keladrin Full Range 10 25th May 2006 11:43 AM
