Dedicated PSU for DEQ/DCX2496 - Page 24 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd December 2007, 10:51 AM   #231
kepa1 is offline kepa1  France
I'm afraid I can't source MBR10100G, can I use MBR745 instead? They are rated 7,5A/45V.
Thank you
Old 23rd December 2007, 03:22 PM   #232
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Merry X mas to all.
I tried the DEQ clock module with a 9v battery and conected the out put to my scope,the XO is from http://www.diykits.com.hk/OPA.htm
Arent the curve supposed to be more Square?
Regards Åke
Old 23rd December 2007, 09:07 PM   #233
jan.didden's Avatar
You may have a high cap load on the circuit. What's your probe cap? Is it a x10 probe?
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 23rd December 2007, 10:11 PM   #234
Ryssen's Avatar
The first pic was x1,
this one is x10:
Is it okay?
Regards Åke
Old 24th December 2007, 06:41 AM   #235
jan.didden's Avatar
this one is x10:
Is it okay?
Well, if anything, it tells us there is a measurement issue. It isn't easy to reliably measure fast signals. For instance, how long is the earth wire of the probe? That's inductance> ringing > see scope pic...
Take a good piece of coax with a BNC on one end. Solder the other end directly to the point you want to measure, with the ground connection also close to that point. Let's see what you have then.
Jan Didden
Old 24th December 2007, 07:46 PM   #236
Ryssen's Avatar
No,it is not..
the probe is not connected,only coax.
Not very good on scope,but does it mean it will work good on DEQ?
Regards Åke
Old 25th December 2007, 08:45 AM   #237
AndrewT is online now AndrewT  Scotland
what frequency are we measuring?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 25th December 2007, 01:37 PM   #238
Ryssen's Avatar
24.576Mhz
Regards Åke
Old 27th December 2007, 09:30 AM   #239
No,it is not..
You need the right tools to have a good measure. Look at the screenshots at the botton of this page. The first measure use a entry level scope (X10 probe), the second use a high end Lecroy scope with an high end probe....
http://www.awdiy.com/index.php?page=miniclock
Vote for the DEQ2496
Old 27th December 2007, 02:27 PM   #240
Ryssen's Avatar
Well I learned sommething new today too..
Regards Åke
One box dedicated headamp/preamp. khundude Pass Labs 5 10th June 2008 03:09 AM
a dedicated piezo amp. Pbassred Multi-Way 2 2nd February 2008 03:58 AM
Why FR may sound better with dedicated HF unit keladrin Full Range 10 25th May 2006 10:43 AM
Copyright ©1999-2017 diyAudio
