DC/DC 12V-15V inducterless Transformer Circuit needed
Old 21st May 2007, 08:27 AM   #1
Tempest_au is offline Tempest_au  Australia
Default DC/DC 12V-15V inducterless Transformer Circuit needed
Here is the problem.
- I need +15V DC 8A output (Constant)
- I can't use coils because if RF issues
- I have +12V DC available as input (Assume at least 20A)
- Cooling is NOT an issue (i.e. I can easily get rid of whatever heat is generated)
I'm not an engineer, and my knowledge of electronic circuits is limited to sub-design level. I can however read circuit diagrams, and have a "basic" knowledge of electrical circuitry.
Can someone out there who knows more than me direct me to where I might find a circuit diagram to enable me to build the circuit described above? I'd prefer it to be reasonably efficient (as in at least 80%), but other than that I don't really care what it takes.
All help greatfully appreciated.
Old 21st May 2007, 12:44 PM   #2
theChris is offline theChris
1.) why do you want a trasnformer.
2.) why do you not want an inductor.
if only it could be used for good, not evil...
Old 21st May 2007, 01:15 PM   #3
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
is electrical isolation from input-output required?
Old 21st May 2007, 01:30 PM   #4
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
This can be done, but the RF issues come not so much from the coil (which if designed properly will have low emissions) but from the necessary high frequency square-wave operation. Without using a coil you will have problems. Capacitor-doubling then regulation will do it, but you will need a truly massive cap bank.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 21st May 2007, 01:43 PM   #5
phase_accurate is offline phase_accurate
You can build some kind of charge pump.
Charge four equal capacitors in series from 12 Volts and discharge them in parallel with their "negative" electrodes connected to the + 12 Volts. But this wouldn't be simpler than using an inductor and it would also only work in non-input/output isolated fashion. It would in fact be quite complicated due to the need for synchronous rectification.
Charles
Old 22nd May 2007, 11:33 AM   #6
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
A charge pump is likely to result in more EMI than a transformer or inductor due to te higher peak currents and current slopes involved when 15*8=120W output is required.
A push-pull ferrite toroid transformer with a pair of MOSFETs with slow gate drive is really quiet in EMI terms. Adding a iron-powder toroid inductor to the secondary side allows to achieve regulation. Furthermore, inductor value and operating frequency may be chosen to achieve discontinuous mode operation, wich produces even lower EMI. Schottky diodes with proper RC snubbers across them also help to achieve quiet operation
I use to feel like the small child in The Emperor's New Clothes tale
Old 22nd May 2007, 01:37 PM   #7
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Tempest-
Well, there you have it. EVA's recommendation is kinda hard to argue with, because, unlike designing linear PSUs, more than just a little bit of design and testing is required to make a good design. Many people can design and fabricate rudimentary SMPSs, but it takes some effort to design a really good SMPS, or refine an existing one.
You could throw together a circuit like EVA describes, and it would work OK, but without the design refinements she describes (slow gate-drive, iron-powdered inductor, operating frequency and discontinuous operation), EMI & RFI will still be an issue. I suggest looking at several design notes before deciding on a strategy. Good design can mitigate RFI issues, it just takes a bit of knowledge, experience and patience.
Recently, I did a 2-F DC-DC boost converter that puts out +19.5V (15-24V adjustable) @ something like 5-6A, using a non-isolated version of the ckt EVA describes. The controller is an SG3525, the MOSFETs are MTP75N06s, and the Schottky diode is an MBR2545CT. I used a bifilar-wound powdered-iron toroid, wound for ~27 mH pr winding. The centertap goes to +12V, and each end is alternately switched on and off, like a push-pull, but without DC-DC isolation. The spikes created at each end of the coil's winding are recovered by the double Schottky, filtered with a C-L-C section, and monitored for regulation. See the attached pic.
Hope this helps. If I figure out how to shring the size of the schematic file, I will post it here.
Steve
DC/DC 12V-15V inducterless Transformer Circuit neededHide this!Advertise here!
Sub amp circuit needed space2000 Solid State 9 4th November 2011 12:23 PM
Help needed with bias circuit Rob11966 Tubes / Valves 18 1st March 2009 04:07 PM
Help needed for H-Bridge circuit xyz9915 Solid State 5 5th May 2008 12:30 PM
pre-amp and tone circuit. Help needed... Scummer Instruments and Amps 10 22nd March 2006 05:01 PM
Active BSC and RC circuit - help needed HiFiNutNut Multi-Way 2 21st March 2005 11:30 PM
Copyright ©1999-2017 diyAudio
