Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 8th July 2017, 10:23 PM   #1
Joca is offline Joca  Portugal
Default Fostex 126en phase plug needed
Hi.
My little daughter just made a predictable thing...fingers on the dust caps. i've tried everything but with no results. Where can i find a phase plug for it? Or maybe someone can tell me how to do one.
Thank you
Old 9th July 2017, 02:01 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
We discontinued ohase plugs for these as sales were slow the only reason to use them is a dustcap damaged beyond recovery.
Have you seen this: FE12x dustcap fix
I have attached the plans for the ones we used to do, and a 3D print file done by a client.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th July 2017, 09:07 AM   #3
Than you very much. I think i will try the phase plugs. my dust caps are in bad condition.
i think that i can remove the dust cap with a xacto but need advice to glue the phase plug. is there any guide out there?
Old 9th July 2017, 08:32 PM   #4
frugal-phile(tm)
planet10's Avatar
Use a pair of steel screws to the bottom of the plug and the polepiece will hold them in place (it is a strong magnet). These leaves the plugs removable & adjustable.
There are some pictorals of dust-cap removal here: planet_10 hifi. RS 40-1197 is closest to FE126.
dave
Old 9th July 2017, 10:06 PM   #5
Thank you very much for the help.
Old 11th July 2017, 12:32 AM   #6
stormfrontier is offline stormfrontier  United States
stormfrontier's Avatar
Just modeled and printed two of these today on our big Fortus FDM 3D printer. Dumped some acetone on them and sanded smooth. Thanks again Dave.
Old 11th July 2017, 01:23 AM   #7
frugal-phile(tm)
planet10's Avatar
Pictures?
dave
Old 11th July 2017, 01:35 AM   #8
Just painted them a grayish-blue to match the EnABL.
Old 11th July 2017, 02:10 PM   #9
Finished them this morning. Very easy to do.
Old 11th July 2017, 04:14 PM   #10
frugal-phile(tm)
planet10's Avatar
Thanx. Those look good.
dave
Fostex 126en phase plug neededHide this!Advertise here!
Radial phase plug vs concentric ring phase plug sean19 Multi-Way 17 7th April 2016 10:20 PM
Singular & Fostex FE206e Phase Plug and EQ Modifications vdbosch Full Range 3 16th October 2009 08:43 PM
Fostex FE206E socket phase plug johninCR Full Range 16 27th January 2008 10:35 PM
Fostex 127E phase plug install kazoo Full Range 42 11th December 2006 07:54 PM
Fostex FE206E phase plug tade Full Range 11 12th September 2005 11:48 PM
