Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 2nd January 2017, 10:35 PM   #11
silverhairbp is offline silverhairbp  United States
bimmer - Outdoor NHL game this afternoon is St. Louis. The Blues beat the Chicago Schmuckhawks 4 - 1.
With a sub, you may not need anything more than a pair of A7.3s. Might not need more than a choke on the sub and a cap on the 7.3. YMMV.
Old 2nd January 2017, 10:41 PM   #12
chrisb is offline chrisb
Originally Posted by davesbimmer View Post
Which of the many MTM's using dual Alpair12PW and single A7.3 and big wood like yours should I consider?
So far I've used that exact combination of drivers only once, and yes the overall cost of drivers wasn't small - but the configuration topology could easily be used with other makes / models.
Our first build of that type was a few years ago, using a now out of production, very inexpensive mid-bass driver (Mark Audio Woofer6 / aka CSS EL166) , and Fostex FF85K. The Alpairs sound much better, but at well over 4 times the driver cost. Boxes were about the same size, with only inflationary increases in material costs.
And to reiterate my earlier comment, I'd be inclined to mostly agree with silverhair with regards to the A7.3 - except that I'd still want to high pass them for safety's sake. A lot of guys here have had great success with them and dual woofers with everything from a fairly simple passive XO to any of several more elaborate bi-amping schemes - which can simply be a hard sell for a lot of folks.
like my mind, this space intentionally blank
Old 3rd January 2017, 12:42 AM   #13
too late to edit above, but I should have said "stereo woofers" - i.e. one per channel - not dual
Old 3rd January 2017, 07:51 PM   #14
davesbimmer is offline davesbimmer  Canada
davesbimmer's Avatar
is this yours?
http://www.planet10-hifi.com/images/A12pwMTM-veneer.jpg
I could live with something that size and shape. I don't want a stand, so I could put a big box under the chamber if it is too big for one w.
Old 3rd January 2017, 10:10 PM   #15
Yup - like I said before, this topology could easily be used with mid-bass drivers costing far less than $135 USD each for stock, and $220 with the EnABL treatment. Do I really want to do the math? - that's $1460 USD * of drivers alone, plus the over $200 for crossover components, then the 3 sheets of Baltic Birch plywood and 2 sheets of quarter cut Sapele veneer, and at least half a gallon of ML Campbell Krystal post catalyzed lacquer. My 50 or so hours of labour probably don't count. . Nope, shouldn't have revisited that.
* USD quoted per Dave's pricing for the treated units used. Current CDN pricing from Bob for stock units would be $990 - all prices before shipping and applicable taxes.
Our first build of this style was with EL166 mid-bass drivers that IIRC sold for about $45 ea? - not quite as pretty as the Alpairs, but still work very well - and the now superceded Fostex FF85K.
These were a statement build, and even a single woofer per side in an enclosure approx half the CSA would work fine - particularly if a sub is available for the heavy lifting below, say 100. Actually, I'm currently using these in my little 7.1 home theatre, crossed over the the LFE channel at THX level of 80Hz, so the dual woofers per side are hardly breaking a sweat at my normal listening levels - well below 90dB A at 3meters in 340sq ft room.
Old 4th January 2017, 03:55 AM   #16
hobbers is offline hobbers  Canada
From the size of your room and type of music you listened to, plus your interest in this style of enclosure, I can highly recommend Woden Designs Victor with the ff165wk.
I've also been enjoying Planet10's mar-ken12pwt. They're more detailed and have beautiful bass but for blues and rock and in a room of yours size I'd pick the Victors. Theyre also very good for movies.
Bernie
Old 4th January 2017, 09:59 PM   #17
Bernie - is that the second pair of Victors?
Old 4th January 2017, 10:35 PM   #18
Hi Chris, yes that's the second pair. Wish I had the first pair still so I could have compared the two. From memory I'd say the ff165wk sounds better then the 166esr's did. These ones are a bit heavier too, I put 30lbs of sand in the voids per enclosure. If I had the space I'd get Scott to design a pair without any size constraints. I believe I read that he said he could extract more from the driver but he kept it to 5x5 sheet size.
Old 4th January 2017, 11:55 PM   #19
Okay, the reason I am not continuing to discuss the single driver is because I have a solid state amp. Others have advised me that that is problematic because of high output impedance.....
Old 5th January 2017, 02:23 AM   #20
Although if someone thought this is wrong, I'm in for the Victor with all that size...The idea of a simple BIG horn is appealling.
Opinions requested to help me select the best horn/fullrange driversHide this!Advertise here!
BEHRINGER SRC 2496 opinions kindly requested. beppe61 Digital Source 81 5th March 2011 07:13 PM
Opinions needed on Tapped Horn drivers zobsky Subwoofers 11 2nd August 2010 02:36 AM
Experienced Opinions Requested : Sub Design Choices pietschu Subwoofers 23 2nd February 2010 08:30 PM
opinions Requested on Xover caps Renron Parts 2 20th February 2007 06:55 AM
Behringer EP1500 - opinions kindly requested. beppe61 Instruments and Amps 0 6th April 2006 09:40 AM
