Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 27th June 2015, 12:22 AM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Lite for 3" drivers
Originally Posted by sideways View Post
Yup yup splendid
Some comments here: FHLite...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th June 2015, 03:58 PM   #12
S4m is offline S4m  Germany
S4m's Avatar
Hi Dave. I have a question about stuffing. Is it the same like on the bigger brother? The Fhlite is so tiny i cannot do it after glueing all parts together. May you have some expert knowledge for a poor diyer?
Old 29th June 2015, 05:24 PM   #13
frugal-phile(tm)
planet10's Avatar
Yes, damping is done the same as the other FHs. The stuff in the point has to be done before the last side goes on. I will figure out some numbers.
dave
Old 29th June 2015, 06:35 PM   #14
sideways is offline sideways  Canada
sideways's Avatar
I stuffed mine the same...just proportionally lower than my regular FH3's...
Old 29th June 2015, 07:47 PM   #15
frugal-phile(tm)
planet10's Avatar
I have done a 1st pass damping plan. It is attached.
The plan linked in the 1st post is also updated…
dave
Old 30th June 2015, 04:26 PM   #16
S4m's Avatar
Thank you very much for both of your advice/plan.
This project needs some time. Tried to realize a first quick build, but the OSB-panels in 12mm didn't like to get cut and smaller parts broke from the edges.
Now i have 18mm oak boards for the side-panels and birch multiplex 12mm for all the other parts.
The contour of the back is now more or less finished; more sanding is needed!
Tomorrow i start with glueing all parts together.
The first speaker-type will be the Aura NS-3. Got a different pair in a very nice 2,5l BR-enclosure. They are playing very low for such small beasts, i hope they are losing the typibal boomy sound of the BR-chamber
Getting nervous!
Old 4th July 2015, 02:55 PM   #17
S4m's Avatar
Hello everyone,
Hope you had a nice Canada-Day
My FHLite-builds are finished and in the "warmplaying-phase".
As written before i started with the Aurasound NS3 and my first impression...WOW!
They need some time for breaking-in but what 'da hell a really well tempered bass!
A much better full deep sound compared to the BR enclosures i build for a different pair.
No Pic No Truth so attached two pictures of my more or less fast build.
My highend testing setup is a Topping TP30 Tripath-amp, a super expensive Philips AEA200/12 Bluetooth-Adapter
and the good old Moto G1 with a lot of *.flac, di.fm and youtube on it
The Topping is a bit sensitive to impedance chages so its not the best choice to use the Aura without compensation.
But for some easy listening its enough. I think for the upper frequency i will add a tweeter or a 1" Aurasound NSW1-205-8A.
I really had a lot of fun with this build. For the sides 18mm oak-panels and for all the other parts as suggested 12mm birch multiplex panels are used.
Dave and everyone behind planet10; thank you very much for all the work and especially the complete free offered plans and advices for this community.
If you were not so far located i would invite you guys to a small BBQ
The Doors - Riders On The Storm......in permanent loop!
Old 4th July 2015, 06:07 PM   #18
frugal-phile(tm)
planet10's Avatar
very pretty.
dave
Old 4th July 2015, 07:01 PM   #19
S4m's Avatar
My very tolerant girlfriend likesthem too...the curve in the back seems to result in a high WAF At the moment we are enjoying a mix between Bob Marley and Massive Attack. They play much bigger than they are. Room is about 18m2 and listening distance nearly 4m...moderate Volumen that normal conversation gets painful, nearly no cone-movement!
Old 7th July 2015, 11:58 AM   #20
sideways's Avatar
My thoughts exactly...they play much bigger than what they are!!
Excellent job!!! I really like the sides!!
Frugel-Horn Lite for 3" driversHide this!Advertise here!
Pics Carfrae Little Big Horn "Lite" - kit atilsley Full Range 7 1st October 2017 11:52 PM
Frugel Horn for Lowther drivers ziocalepino Full Range 8 23rd August 2012 09:33 PM
FS: Frugel-horn MK3 Flatpacks with EL70eN^2 Drivers wiatrob Swap Meet 1 27th August 2011 07:00 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
Commercial "Tribute" to the Frugel-Horn? klykx Full Range 85 4th August 2010 09:28 AM
