Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 14th July 2017, 09:05 PM   #181
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Lite for 3" drivers
Originally Posted by twocents View Post
Hi Dave, I see this Scanspeak is a 4" driver - will it fit in the FH Lite?
Same size as the 10F/8224, it should fit.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th July 2017, 11:12 PM   #182
frugal-phile(tm)
planet10's Avatar
Originally Posted by Elias Zacharopoulos View Post
Dave I just show Alpair 10p Mark Audio Alpair 10P-A Fullrange Loudspeaker Measurements Data and Information Full Range and I don't like at all the curves I see. In contrast, the curves that given at B10-A10 are almost perfect. Witch of the two is the real one ? Elias
I donít pay a who;e lot of attention to peopleís measurements, as you donít really know the context.
I find the Alpair 10p quite nice sounding (caveat: most of my listening with the A10PeN)
dave
Old 15th July 2017, 11:01 AM   #183
Elias Zacharopoulos is offline Elias Zacharopoulos  Greece
Grafs are copied right now from www.hifisound.de
How 10F/8424G00 characterised as midrange in contrast to
10F/8414G10 characterised as fullrange. As anyone can see Resonance fs fs: 90 Hz for 10F/8424G00
Resonance fs fs: 100 Hz for 10F/8414G10
furthermore above 10KHz the graf on axis for the former looks to me better
Old 15th July 2017, 07:53 PM   #184
frugal-phile(tm)
planet10's Avatar
I havenít heard the 8414 yet, but the 8424 we have are decidedly soft on top. The 8414 has a higher Qt which gives it more bass. Sims attached. Sealed + a close to flat reflex (the 8414 box can be 2x the 8424. The 8414 has better LF possibilities.
dave
Old 15th July 2017, 09:52 PM   #185
dave
Thank you for the grafs Dave.
I appreciate it very much.
Elias
Old 15th July 2017, 10:04 PM   #186
frugal-phile(tm)
planet10's Avatar
You are welcome.
dave
Old 27th February 2018, 08:11 PM   #187
markgoespop is offline markgoespop  United Kingdom
Is the Visaton FRS 8 (params below) likely to work in the FH Lite? Anyone modelled it, built one, or willing to guess?
Rated power 30 W
Mean sound pressure level 82 dB (1 W/1 m)
Excursion limit +/−2,5 mm
Resonance frequency fs 120 Hz
Magnetic induction 0,8 T
Magnetic flux 200 ĶWb
Height of front pole-plate 4 mm
Voice coil diameter 20 mm
Height of winding 4,5 mm
D.C. resistance Rdc 7,2 Ohm
Mechanical Q factor Qms 4,85
Electrical Q factor Qes 1,32
Total Q factor Qts 1,04
Equivalent volume Vas 0,9 l
Effective piston area Sd 31 cm≤
Dynamically moved mass Mms 2,5 g
Force factor Bxl 3,2 T m
Inductance of the voice coil L 0,9 mH
Old 27th February 2018, 08:28 PM   #188
frugal-phile(tm)
planet10's Avatar
Fs is kinda high, it will likely need a lot of stuffing and bass (well bass as low as the FH-Lite goes) will likely be elevated.
dave
Old 28th February 2018, 12:00 AM   #189
Thanks!
Old 17th March 2018, 08:09 PM   #190
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
A little late to the party, but FWIW, both the 8ohm & 4ohm versions of the FRS8 will work fine, especially if you have a corner to load it. The FRS8M with its larger motor will also work well, but may benefit from slightly resistive wiring. All three should be quite nice, especially for the money.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Frugel-Horn Lite for 3" driversHide this!Advertise here!
Pics Carfrae Little Big Horn "Lite" - kit atilsley Full Range 7 1st October 2017 11:52 PM
Frugel Horn for Lowther drivers ziocalepino Full Range 8 23rd August 2012 09:33 PM
FS: Frugel-horn MK3 Flatpacks with EL70eN^2 Drivers wiatrob Swap Meet 1 27th August 2011 07:00 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
Commercial "Tribute" to the Frugel-Horn? klykx Full Range 85 4th August 2010 09:28 AM
