Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 12th March 2017, 01:11 PM   #161
inrank is offline inrank  United Kingdom
inrank's Avatar
Hi, I have a pair of Omnes Audio BB3.AL spare, and looking at the specs, they are very close to the FF85WK.
Do you think they might work in this design?
FS = 94Hz
VAS = 1.6L
MMS = 2.1g
SD = 29.2cm2
Qts = 0,5 (Qms=6,2, Qes=0,54)
Omnes Audio BB3.AL
Old 12th March 2017, 05:08 PM   #162
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Frugel-Horn Lite for 3" drivers
Dave is out of commission. Chris is on holidays right now and is only checking in from time to time so please be patient awaiting an answer.
planet10 needs your help:
Let's help Ruth and Dave
Old 21st March 2017, 05:40 AM   #163
musiklava79 is offline musiklava79  India
Originally Posted by giantstairs View Post
Would the Alpair 6 Gen1 work well in these cabs? Or would it do better in the regular size Frugal-Horn cabs?
The introduction of the Frugel-Horn Lite plans describes which drivers are suitable for the enclosures. The A6s are also mentioned but you'll have to use SupraBaffles to accommodate the larger drivers. You'll find a good description of the SB in the FH3 plan set (11th Page) titled Baffle Cutout. You can leave out the side wings if you like.
The A6s are not suitable for the larger FH3s, I think.
Old 21st March 2017, 05:49 AM   #164
FS = 94Hz
VAS = 1.6L
MMS = 2.1g
SD = 29.2cm2
Omnes Audio BB3.AL
There's no reason why you can't use these drivers in the FHLs. The Aura NS3 drivers with Fs 80Hz have been successfully tried out. The MA A5.2s have Fs 101 Hz and I'm enjoying these drivers presently. Only, you will have to adjust the front dampening for the lower Fs and experiment with it to suit your taste.
I suggest that you should use removeable baffles that you can try out different drivers later, if you like.
Old 21st March 2017, 11:34 AM   #165
giantstairs is offline giantstairs  Spain
Thanks Musiclava for the reply. I have already read the document but it specifies the alpair 6.2 and I don't recall any mention of the gen 1. If I remember correctly gen 1 has a pensil designed for it but 6.2 was deemed unsuitable. So would like some reassurance that it is a good fit in this cab before cutting wood.
Old 21st March 2017, 02:21 PM   #166
...I have already read the document but it specifies the alpair 6.2 and I don't recall any mention of the gen 1. If I remember correctly gen 1 has a pensil designed for it but 6.2 was deemed unsuitable. So would like some reassurance that it is a good fit in this cab before cutting wood.
Hi giantstairs,
The pensil series is a driver-specific design. The Pensil was designed for the A6.1 and hence is unsuitable for the A6.2. The TSPs of both drivers differ from each other.
On the other hand, the FHLs, like the larger FH3, is a flexible design that can accommodate a large variety of 3” to 3.5” drivers, your A6.1 included, although it was not mentioned in the list. The rider is that you must be prepared to experiment with the front dampening to get the correct sound quality and to suit your taste. The original FHL was designed around the Fostex FF85WK so the published dampening quantities are suitable for these drivers. This will also serve as a guideline for experimenting with your own drivers. I’ve already tried out four different drivers so far and have faced no difficulty whatsoever. I plan to try out more drivers in future.
Go ahead with your build. Nothing’s going to go wrong. Just be prepared to spare some time for tweaking the front dampening. Good luck!
Old 21st March 2017, 05:30 PM   #167
Thanks! Just the push I needed to get these started.
Will report back but may take a while, I've got a few projects further up the queue.
Old 22nd March 2017, 09:00 AM   #168
inrank's Avatar
Thanks very much, I'll give it a try!
Old 6th May 2017, 08:32 PM   #169
inrank's Avatar
CNC kit arrived from Stefan @ KJF Audio (Speaker Kits | KJF Audio) and its a perfect, easy kit to assemble.
Test fit....
During....
Final side....
And one finished....
Old 6th May 2017, 09:08 PM   #170
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
What driver are you using?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Frugel-Horn Lite for 3" driversHide this!Advertise here!
Pics Carfrae Little Big Horn "Lite" - kit atilsley Full Range 7 2nd October 2017 12:52 AM
Frugel Horn for Lowther drivers ziocalepino Full Range 8 23rd August 2012 10:33 PM
FS: Frugel-horn MK3 Flatpacks with EL70eN^2 Drivers wiatrob Swap Meet 1 27th August 2011 08:00 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 02:28 AM
Commercial "Tribute" to the Frugel-Horn? klykx Full Range 85 4th August 2010 10:28 AM
