I have made speakers with the moisture resistant mdf - denser and harder than regular and less dust when cutting. Still takes some bracing though to really sound good - I'd brace more than shown in pics so far if using this material. Probably even then not optimal for the last smidgen of performance, but cheap enough if that is needed. Not totally horrible.
First ones are out in the wild.
http://www.lencoheaven.net/forum/index.php?topic=19787.30
There is still a lip. But about 5mm or so.
That might catch the 1st seal on the gasket, won't reach the secound one.
Maybe Chris could post a pic of the A10 cutout in the FHXL he is currently veneering.
dave
Full disclosure - I experimented with a single layer of 18mm ply for baffles on these, without chamfering the rear side of mounting hole. While this is the opposite to approach that many builders are using, it seems to work fine. With a high quality multi-ply, and carefully sized pilot holes and pre-tapping with the MA supplied screws, I think the 8mm of core remaining after rebating is sufficient.
I wouldn't to this with A7s and 18mm baffle.
Another pair out in the wild:
A few more details here:
FrugelHorn XL - Audio Forum | Graham Slee Online Owners Club - Page 1
For some reason I can't see BackinBlack's pictures so here they are again...
I happen to prefer all the Alpairs I've heard in vented or BLH boxes, but why not. I guess the size would depend on the intended application - modelling suggests you can get pretty tiny with either of the 10s if you plan on adding woofers as high as 110 -120 Hz
OT a bit from that question - any reason why you've not thought about a CNC kit for the FH3? The A7.3 sounds quite wonderful in that one - indeed, my favorite for that driver when floor space is available.
- More Vendors...
- Planet 10 hifi
- CNC kits for Mark Audio. UK
