Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 27th November 2013, 10:37 PM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
WoofT height?
Originally Posted by zman01 View Post
when bi-amping, won't mudchute need a XO solution like MiniDSP?
So far we have found in situations like this that 1st order PLLXO can be made to work fine. Should have a big sonic advantage over miniDSP, especially in an analog system, althou not as versatile. 4 caps, 2 resistors. If you decide to put it in a box with connectors, that -- and the extra cables -- will swamp the price.
Thanx Zia for mentioning the Class D amps, they can work well.. I have one of the 4x100W Sure anps for my subwoofers.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th November 2013, 09:55 AM   #12
mudchute is offline mudchute  United Kingdom
Are the mentioned amps a power amp or pre and power?
Old 28th November 2013, 06:27 PM   #13
frugal-phile(tm)
planet10's Avatar
WoofT height?
Power amps. You will need a pre-ampto use a PLLXO.
dave
Old 28th November 2013, 07:47 PM   #14
Maybe i'll stick an old integrated for simplicity then.
How's about that driver? If nitrogen, is there anything in particular I should be looking for?
Old 28th November 2013, 08:03 PM   #15
frugal-phile(tm)
planet10's Avatar
WoofT height?
Originally Posted by mudchute View Post
If nitrogen
I haven't gad a chance to look at either of the drivers yet.
dave
Old 28th November 2013, 08:43 PM   #16
Predictive text + excitement over new things = dodgy writings!
Re the drivers, Is there anything in particular I should be looking for?
Old 28th November 2013, 09:26 PM   #17
chrisb is offline chrisb
much clearer now
which driver, "that" ?
like my mind, this space intentionally blank
Old 28th November 2013, 09:30 PM   #18
The 5 & 1/4" monacor at the bottom of page 1?
There's soooo many drivers that I don't know where to start!
Old 28th November 2013, 09:31 PM   #19
Ebay item = 221320374760
Old 30th November 2013, 02:02 AM   #20
frugal-phile(tm)
planet10's Avatar
WoofT height?
Seas-L18rnxp-h1224
2 of these will work in a woofT. With a full length bevel on the front they will just barely fot on the sides, with the bezel only long enuff for a cosmetic match, it will easily fit. These will get to an F10 of about 40 Hz. It should be possible to get a tiny bit lower with the bevel only cosmetic, or some other trick to get a bit more volume.
The real peaky bits, even with just a 1st order PLLXO at 160 will be down quite a bit. My experiments suggest that a coat of puzzlekoat will go a long ways to suppressing it as well.
dave
WoofT height?Hide this!Advertise here!
Turntable height davecooper Analogue Source 0 20th July 2013 08:57 AM
Golden Ratio Height edjosh23 Full Range 13 3rd February 2009 09:52 PM
BIB and ceiling height Mr.Mekulic Full Range 7 21st November 2007 07:58 PM
Can Ariel's height be reduced? zdr Multi-Way 1 18th May 2007 09:40 AM
