Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 9th October 2013, 07:52 PM   #1
BuildMeSomething is offline BuildMeSomething  United Kingdom
Default Sealed Enclosure for A7.3
Hi, I'm after plans for building sealed enclosures for the Alpair 7.3 to be used as the 5 in a 5.1 HT setup.
I've had a good trawl through the site and found some nice bits of info, however being new to this game, I wouldn't know how to use half of it... An existing design would be ideal.
Had a look on frugal-file, the mMars for A7 appears to fit the bill. Is this plan-set relevant to the 7.3 and available?
Thanks,
Paul
Listening with Gusto!
Old 9th October 2013, 08:12 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by BuildMeSomething View Post
Had a look on frugal-file, the mMars for A7 appear to fit the bill. Is this plan-set relevant to the 7.3 and available?
Same box as mMarS for CHR70 but modified to fit the A7.x
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th October 2013, 08:58 PM   #3
Thank you Dave
Are the plans on frugal-file the complete set, or do I need to purchase them?
Last bit, is there a recommended [roughly speaking] XO point for the mMarS. Though my HT amp does a full auto speaker setup & EQ it might be better to set this point manually. IIRC, 40, 60, 80, 100 & 120Hz are available.
Paul.
Old 9th October 2013, 09:27 PM   #4
frugal-phile(tm)
planet10's Avatar
mMarS for CHR is freely downloadable. Rebate & driver brace need adjusting.
dave
Old 9th October 2013, 09:40 PM   #5
OK, thank you
Paul.
Old 16th December 2013, 11:30 PM   #6
Quick question... I have enough 18mm B/B plywood left over to build 1 pair of the mMarS. Any reason not to use 18mm through out... or 18mm on baffle only and 15mm else where?
Paul
Old 16th December 2013, 11:47 PM   #7
frugal-phile(tm)
planet10's Avatar
No resaon to not use 18mm
dave
Old 17th December 2013, 12:04 AM   #8
Cheers
Old 16th February 2014, 11:01 AM   #9
OK... 90% cut, just the internal braces to trim & make holey
Cut the front baffles to flush mount the A7.3. Material thickness behind the driver is 9mm, is it worth chamfering the back edge of the cut out?
Paul
Old 16th February 2014, 08:08 PM   #10
chrisb is offline chrisb
Paul
For the 7cm series (7.3, CHR, etc) I'd say yes, with the 10's I'll confess to not chamfering the backside of my last 3 builds, with no discernable detriment ( at least with my hearing and raging tinnitus)
kinda burnt out - taking a break
Sealed Enclosure for A7.3Hide this!Advertise here!
Sealed enclosure experiment d1030180 Multi-Way 53 15th August 2013 01:05 AM
Help best sub for sealed enclosure harmonizer Subwoofers 7 5th August 2011 09:55 AM
Sealed enclosure questions.. Defo Multi-Way 6 21st February 2009 03:54 AM
Jordans in sealed enclosure? billnchristy Full Range 3 19th November 2006 05:23 PM
Small sealed enclosure Ddeele Subwoofers 15 20th January 2005 09:50 AM
Copyright ©1999-2017 diyAudio
