Sealed Enclosure for A7.3 - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Planet 10 hifi
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 16th February 2014, 10:09 PM   #11
Thanks, I managed to remove an A7.3 from the FH3 and do a test fitting. Does look like it'd benefit from a chamfered rear edge. Will do this in the morning...
Going to order some copper coloured 7.3s for these enclosures
Listening with Gusto!
Old 30th March 2014, 07:42 PM   #12
Default Very Nearly Done
Currently have a lot of projects underway and all nearing completion, with final details taking the most amount of time.
Had the mMarS sat on one side for a few weeks waiting the arrival of the A7.3 drivers. These arrived just over a week ago and gluing began mid week. The driver rear braces are trimmed, requiring a slip of paper for nice fit... Internally, used needled cotton felt.
Initial level sanding with 60 & 80 grit and routed the round-over [R=14mm], then sanded down with 80, 180 & 240 grit... applied some acrylic sanding sealer, sanded again with 180, 240 & fine wire wool. Will get some furniture wax to finish off...
B/B and Walnut veneer were leftovers from other builds. Both rears were slightly proud and needed ~1mm removed to level them [not so pretty looking]. Overall very happy & am pleased that my building is improving.
Should have these playing in the not to distant future
Big Thanks
Paul
Old 31st March 2014, 08:45 AM   #13
Nice.
Old 1st April 2014, 10:41 PM   #14
chrisb is offline chrisb  Canada
tidy work indeed
... so, not as easy at it sounds, this letting go thing
Sealed enclosure experiment d1030180 Multi-Way 53 15th August 2013 01:05 AM
Help best sub for sealed enclosure harmonizer Subwoofers 7 5th August 2011 09:55 AM
Sealed enclosure questions.. Defo Multi-Way 6 21st February 2009 03:54 AM
Jordans in sealed enclosure? billnchristy Full Range 3 19th November 2006 05:23 PM
Small sealed enclosure Ddeele Subwoofers 15 20th January 2005 09:50 AM
Copyright 1999-2017 diyAudio
