Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 30th June 2013, 02:30 AM   #1
zman01 is offline zman01  Bangladesh
Difference in port depth?
Default Difference in port depth?
Dave,
Would like to draw your attention to the CGR dCHR-Ken plans.
There are 2 versions - one wide and shallow, and the other narrow and deep. Though box dimensions are same, I see a difference in port size. Screenshots from plans attached for your reference.
Can you explain please?
Also see something like a "divider" in the port for the narrow-deep plan (I have drawn a red arrow indciating it) - but no measurements.
- Zia
Old 30th June 2013, 03:05 AM   #2
Jsixis is offline Jsixis  United States
port depth sizes vary according to the size of the whole and round vs square, the sound is the same although some people can claim to hear a difference.
As a amateur speaker builder I always aim for the least complicated port
Old 30th June 2013, 04:15 AM   #3
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
I'll have to do some checking, i suspect that the narrow/deep should not have a vent spacer.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th June 2013, 05:27 AM   #4
dave
Thanks Dave.
Appreciate if you can come back on the port depth also - 204 mm vs 226 mm as per the drawings.
Zia
Old 2nd July 2013, 05:39 AM   #5
Dave, gentle reminder on checking the port size.
Old 2nd July 2013, 06:13 AM   #6
frugal-phile(tm)
planet10's Avatar
I'm on slow right now... it is in the queue.
dave
Old 2nd July 2013, 06:28 AM   #7
frugal-phile(tm)
planet10's Avatar
Just checked. They are both correct. You will note that the wide has a lomger vent so needs nore x-section. If you wanted you could exchange the vents -- they are equivalent
dave
Old 2nd July 2013, 08:35 AM   #8
Thank you Dave.
Old 28th September 2013, 07:55 PM   #9
glemmy is offline glemmy  Sweden
Just checked. They are both correct. You will note that the wide has a lomger vent so needs more x-section. If you wanted you could exchange the vents -- they are equivalent
dave
Hi Dave,
sorry but I did not quite catch the explanation in your post.
I'm in the middle of a build of the narrow ones and I have made a mistake making the port a half cm too long (I am using thicker panels).
But looking at the drawing the wide speaker's port is 15x142x226mm and the narrow should be 15x142x204.
So should there be a divider in the middle of the narrow speakers's port as the drawing suggests? (although there are no length-dimension for this divider and it can only be seen in front view).
Thank you
Old 29th September 2013, 05:05 AM   #10
frugal-phile(tm)
planet10's Avatar
The speacer runs all the way to the back. If you made the shelf too long the width of the spacer will need to decrease. I can recalc (but not tonite i'm knackered). The vent is exactly 1 cm too long?
dave
Difference in port depth?Hide this!Advertise here!
Depth of baffle step tvrgeek Multi-Way 12 19th May 2012 12:13 AM
Is there a difference where the port is? carshateme Car Audio 8 5th November 2011 12:08 AM
Stage Depth?!? And why i have none!?! thunk303 Multi-Way 63 8th December 2009 01:50 PM
To port or not to port? Newbie with newly built mains starquake Multi-Way 1 18th December 2004 12:51 PM
