Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 9th March 2013, 01:08 PM   #11
wcwc is offline wcwc  United States
Dave,
Do you remember the dimensions of the 6 L sealed box?
Old 9th March 2013, 06:32 PM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Would this work?
The only dimension in the sim is volume. Any set of dmensions (excluding radical aspect ratios) that give 6 litres internal volume and allow you to fit the driver would work.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th September 2016, 05:52 PM   #13
I am currently building an ACA amp. So at 6 amps which driver would you use? 7.3 or one of the 10's. I plan on running them with my AV receiver pre-outs for the short term. I don't currently have subs, but I plan to add some next year. I was thinking that High Passing the 7.3 instead of the 10.2 makes the most sense. I plan to use the speakers as mains in a music/HT setup.
Old 19th September 2016, 08:00 PM   #14
frugal-phile(tm)
planet10's Avatar
Would this work?
6 watts.
I use ACA with all 3 of these drivers. A10p are the most efficient thou, so if you have a big room or like to turn it up the A10p.
dave
Old 20th September 2016, 02:04 AM   #15
Which has the bigger box between the 10p and the 10.3. I was looking at a Mar-Ken type enclosure. No sure if I would go to the extreme of the trapezoidal enclosure.
Old 20th September 2016, 02:21 AM   #16
frugal-phile(tm)
planet10's Avatar
Would this work?
There are 13 & 17 litre Mar-Kens for the A10p, 13 litre for the A10.3. Smaller versions are also doable but they may start looking kinda squat.
dave
Would this work?Hide this!Advertise here!
Alpair 6M build TISONN Full Range 15 28th August 2013 05:32 AM
StevenZ's Alpair 12P Build StevenZ Full Range 129 9th October 2012 02:56 PM
FAST Build: Alpair 7.3 - Seas L26ROY Swifty Full Range 28 26th June 2012 08:27 AM
Alpair 10.2 home theater build KrunktheMadMan Full Range 4 15th September 2011 11:03 PM
Mark Audio Alpair For First Build? d3ll Full Range 10 17th December 2009 08:11 PM
Copyright ©1999-2017 diyAudio
