Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 6th February 2013, 04:40 PM   #1
Malco is offline Malco  Guatemala
Default Modelling the Pensil CHR70 with the Martin King Spreadsheets
Hi, I'm trying to get familiar with the Martin King spreadsheets and I thought a good place to start would be modelling the Pensil with the CHR70.
I did this using the "open ended with offset driver" spreadsheet and the results look like what I would expect, smooth with an f3 of about 60Hz.
I then tried using the "driver in a mass loaded TL" spreadsheet using the same dimensions but treating the slot as a 3"dia and 0.75" long port. The response for this one is a lot different with a significant peak (+7dB) at about 60Hz.
I would expect the 2 curves to be similar, am I doing something wrong? Any help would be great.
Old 6th February 2013, 05:05 PM   #2
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
The MLTL sheet is the one you need. Make sure you're following the damping configuration as well.
The vent dimensions in Martin's worksheets as-is specify the radius of the vent, not the diameter.
Old 6th February 2013, 05:37 PM   #3
I have the port entered as 1.5" Radius. I am assuming that the port area should match the area of the slot and the change in form (rectangular to round) has little effect.
Attached (I hope!) is the response.
Old 6th February 2013, 05:43 PM   #4
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Are you modeling the original Pensil, or the Pensil70R that Scott did?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th February 2013, 05:44 PM   #5
This one:
http://www.frugal-phile.com/boxlib/p...-R70s3-map.pdf
Old 6th February 2013, 08:09 PM   #6
Scottmoose's Avatar
No you're not. Not at the moment anyway.
Have you modelled the damping correctly? My guess is that you've entered the specified damping quantity into the main data entry section, but this only covers the length / volume from the throat to just below the driver. The damping in the pensil is uniform throughout the enclosure so you need to manually add the appropriate ammount of damping to the rest of the box model (under the open and bottom end of enclosure sections).
Old 7th February 2013, 01:19 AM   #7
Thanks, that helps a lot, looking a lot better now!
Modelling the Pensil CHR70 with the Martin King SpreadsheetsHide this!Advertise here!
Martin King OB first time NYCOne Full Range 3 3rd January 2011 10:55 AM
Martin King`s Fe167e MLTQWT hacknet Full Range 0 18th May 2004 12:43 PM
help designing an martin king TL matjans Multi-Way 7 17th November 2003 02:11 PM
Martin King: Is it just me or quarter-wave.com is down? Thanks JC Fardo Multi-Way 7 12th September 2003 11:15 PM
