Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 16th November 2012, 12:24 PM   #11
RickH is offline RickH  United States
Chris - you mentioned being able to make both speakers from a single sheet or offcuts. I've approximated the area for the all the pieces required and it looks like a 2' x 4' sheet would be more than enough. Does that sound correct?
Thanks,
Rick
Old 16th November 2012, 05:53 PM   #12
chrisb is offline chrisb
Thanks,
Rick
yup, these are not huge boxes - I'm so often cutting for multiple pairs of kits for the smaller designs or using offcuts that I can't remember the breakout for a single pair
like my mind, this space intentionally blank
Old 16th November 2012, 07:39 PM   #13
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
FF85WK uFonken vs. Bass Reflex
When we were making the 1st batch of uFonken, i seem to recall Chris said he could get 5 pair out of a 5x5 sheet of 12mm BB.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th November 2012, 07:51 PM   #14
dave
that sounds about right
Old 16th November 2012, 08:54 PM   #15
frugal-phile(tm)
planet10's Avatar
I went ahead and did the drawing. With no trim allowance, & a 5mm kerf you can get 1 pair out of a 251mm sreip 1314mm long. So with care you should be able to get 2 pair out of a 24" x 48" panel of 12mm.
So you might be able to get 6 pair out of a 5x5 sheet with careful optimization. Close enuff that less trim allowance, and a smaller kerf might make the difference.
dave
Old 16th November 2012, 10:19 PM   #16
dave
when cutting this quantity of parts on the big beam saw, we need to allow 5mm kerf for the main blade, and 10mm trim cuts, but I'm sure there was still a little left over from the 5 pair
Old 20th February 2016, 05:15 AM   #17
RolandPSP is offline RolandPSP  Romania
how low do these go ?
Old 20th February 2016, 05:19 AM   #18
frugal-phile(tm)
planet10's Avatar
uFonken gets to about 70Hz F10, the new slighly larger uFonkenPlus goes 5 Hz lower.
dave
Old 17th March 2016, 02:27 AM   #19
Jimmy154 is online now Jimmy154  United States
Jimmy154's Avatar
uFonken^2 has two drivers per enclosure?
Do you have a link?
Old 17th March 2016, 02:52 AM   #20
frugal-phile(tm)
planet10's Avatar
Yes. The existing design is for the original FF85k.
dave
FF85WK uFonken vs. Bass ReflexHide this!Advertise here!
Fostex FF85WK in uFonken ebag4 Full Range 4 9th September 2012 01:28 PM
Bass Helper Recommendations for FF85WK? goody75 Full Range 13 23rd February 2012 02:32 AM
Fostex w/ Bass Reflex? theseum Full Range 21 18th April 2006 10:07 AM
Bass Reflex Guss Multi-Way 1 15th December 2003 02:33 AM
bass reflex? GAK Multi-Way 2 23rd October 2001 03:04 AM
