Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 29th March 2012, 06:02 PM   #31
doggy is offline doggy  Canada
doggy's Avatar
Thanks planet10 and chrisb for the considerate responses. The musicality of the small driver is true; i have experienced this with the vintage tan colored "holey" basket vintage alnico but cannot take much power. So i prefer drivers that are durable; the fe126 was good considering but am looking for that musical sound and also a speaker that disappears in the sound stage. Have also been trying to read about eNabl. Can the EL70 produce this effect and what is the best cabinet for soundstage? articulate bass is important. The pensil is a bass reflex? and the Fmk3 is a horn with a bottom choke point?
Old 29th March 2012, 07:03 PM   #32
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
uFonken88
Pensil is an ML-TL. FH3 is a horn, the choke at the bottom being a variant of Klipsch's rubber throat (did i get that right Scott?).
EL70 is a wonderful driver, very good in its own right, and very high bang for the buck on topof that, even better treated (to many ears -- the demo pairs (treated/untreated) mMar-Kel70 have gone out and the people auditioning haven't perceived a difference, some people hear a difference right away (and in blind tests -- don't know whether you'd call them dounle blind -- system set up in advance, switchbox, speakers hidden, test self administered with the setup person no where in sight).
It does not have the DDR of something like an Alpair7.3 (also treated) but this gives it an edge with lesser amplifiers, is more robust, and has the capability of an amazing LF extention.
The best finesse in the bass (of the boxes i have heard) are the full-size Mar-Kels, then the FH3, then the Pensil. How low they go is the inverse of that (ie more extension usually means giving up some control/finese)
Chris is currently working on WoofTs (with 2xEL166 per) for our proto wide Trapezoid Mar-Kels. The WoofTs will act as integral, cosmetically matched stands, with the Mar-Kel70wT inverted on top of them
It will be very interesting to see how they do when relieved of the heavy lifting, and with even more extension and weight in the bass. Zia is working on an integrated variation of the same theme with the same drivers.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th March 2012, 07:07 PM   #33
frugal-phile(tm)
planet10's Avatar
uFonken88
PS Doggy
Any chance you can make it to this year's diyFEST? A nice drive thru Manning Park
dave
Old 29th March 2012, 07:18 PM   #34
chrisb is offline chrisb
Pensil is an MLTL - aspect ratio of internal dimensions drive it toward the 1/4 wave end of the continuum .
Yes, the FH3 is a BLH type with bottom choke point - if you like, Scott or Dave could give you a more techno-geek description.
The FE126E doesn't disappear as much as do the EL70 or Alpairs (7.3 particularly) - more so than many drivers in this weight class (including the FF125WK) the FE126E lets you know it's there.
edit: Dave beat me to the punch while answering the phone - and no doubt he was multi-tasking as well
like my mind, this space intentionally blank
Old 29th March 2012, 09:50 PM   #35
doggy's Avatar
Yes, I think I can make it, I have a tent and gear
Old 29th March 2012, 10:24 PM   #36
frugal-phile(tm)
planet10's Avatar
uFonken88
You'll have fun.
dave
Old 4th April 2012, 12:56 AM   #37
fakeout is offline fakeout  Canada
fakeout's Avatar
I'm going to link to Planet10' post on the cabinets for the Fountek FR88EX. The Fountek Five for FR88ex
Old 4th April 2012, 01:45 AM   #38
frugal-phile(tm)
planet10's Avatar
uFonken88
Thanx FB.
dave
uFonken88Hide this!Advertise here!
