Pensil P70 mathematics - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Planet 10 hifi
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 6th November 2012, 08:56 PM   #11
Waves73 is offline Waves73  United Kingdom
Itís been a while since my last post so I thought Iíd give an update on the Pensil build. Finding time to dedicate to the build has been tricky but I think Iím nearly there.
This is the first speaker build Iíve done but me being me, I couldnít just follow the plans, I had to tinker.
As you can see from the pictures Iíve used a piece of walnut on the baffle, where the driver sits. As the walnut width is a few millimetre smaller than the plans I re-calculated the speaker and vent dimensions to maintain the original volume.
Lesson 1: Check measurements. Check measurements. And check again.
As the eagle eyed reader has probably noticed, the cleats for fixing the back panel are flush with back of the cabinet. After much swearing and rechecking of measurements I had to accept Iíd got it wrong and the only way to get around this without scrapping the wood was to trim the side panels and have the back panel fixed directly on, rather than set in. This now means Iíve got a bit of a job to make sure the seal is as airtight as I can make it.
One of the hardest things Iíve found with the build is cutting the plywood accurately. Trying to make millimetre accurate cuts with a circular saw is pretty difficult. And even when using hand saws, getting everything exact has taken some patience.
How sensitive is the Pensil design when it comes to measurements? Even re-measuring and re-calculating every time I cut and sand panels their are still slight differences between what I have and the plans.
Hoping to get the cabinets finished this month and then start designing and building the centre speaker. Final stages are to sand, paint and add the stuffing before fixing the drivers and start to test the speakers. The plan is to paint the main body of the cabinet white and wax the walnut. This should look fantastic once the natural paper CHP70ís are fitted.
Iíll post more pictures as I progress.
Mark
Old 7th November 2012, 08:07 AM   #12
Scottmoose's Avatar
The alignment deliberately has a high internal volume since it's meant to be flexible; as such, within reason, a mm or so out isn't the end of the world.
Pensil P70.3 build malibujeff Planet 10 hifi 19 10th January 2012 10:26 AM
My first build - Pensil P70 JorgeO Planet 10 hifi 9 28th June 2011 02:51 PM
Cutting plans for Pensil 12 and Super Pensil zman01 Planet 10 hifi 3 24th March 2011 04:48 AM
Heavely modified Pensil P70, or how to do a ML-TQWT for the CHP-70 Squeak Planet 10 hifi 0 11th March 2011 10:18 AM
16=20 or the mathematics of RCA Christer Digital Source 13 16th June 2003 05:58 AM
Copyright ©1999-2017 diyAudio
