Full-Range Drivers - adjustment - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Planet 10 hifi
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 10th February 2012, 06:35 AM   #11
chris661's Avatar
If you want bright, I'd start off with some of the now discontinued Fostex drivers (eg, FE126 or FE127), and add a notch filter, replacing the resistor with a variable resistor so you can make some adjustment.
I don't think the Mark Audio drivers will satisfy the need for a bright sound.
Chris
Old 10th February 2012, 05:00 PM   #12
chrisb is offline chrisb  Canada
FWIW, I occasionally use my 5.1 system(all Mark Audio Alpairs except for wooofers) in 5 channel stereo mode, wherein it plays much louder at the same volume setting than in Dolby DTS, or any of the synthesised modes. Even so, the "small" Alpair 7 & 6s have no trouble filling a 320sq ft room to a very comfortable level.
Chris661 has an excellent point: not only would certain models of Fostex drivers (current FE126En / FE166Enor older FE127E , etc if you can find them) have more of an upwards tilted response hump than the Mark Audios, but they (Fostex) can also demonstrate a very forwardly dynamic (in yer face) presentation that may or not be to your liking.
Note that any of the FExx6 series tend to work best generally in BLH type enclosures when used "full range". In smaller vented boxes they'll have very limited LF response, which can be taken advantage of in a multi-channel application with supporting woofers.
on hiatus
Old 11th February 2012, 04:22 AM   #13
zman01 is offline zman01  Bangladesh
Chris
The CHR-70.3 should be commensurate regarding this aspect. I have CHR-70.2 and treble is aplenty.
-Zia
Korean Sonodyne S-654 Full-Range/Wide-Range Drivers thetubeguy1954 Full Range 6 18th January 2011 10:42 PM
I know there are more full range drivers . . . what about . . . Kensai Full Range 21 19th December 2005 04:50 PM
Full range drivers. tade Full Range 5 2nd March 2005 02:59 PM
Copyright 1999-2017 diyAudio
