Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 11th June 2011, 06:21 PM   #11
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
That doesn't mean they're doing it perfectly (it would appear they aren't).
Yes. The more you can do to minimise reflections / sharp edges, the better.
Old 11th June 2011, 07:47 PM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
First build ever: Pensil 10.2 - in solid oak
Here is Mark's recommendation.
We take it a bit further and put a full 45 degrees instead of a curve. This directs any energy to the back of the box.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th June 2011, 07:49 PM   #13
frugal-phile(tm)
planet10's Avatar
Originally Posted by Swifty View Post
Ok, so you would recommend me to take a file to those edges? If I look at the cabinets done for Musik007 I'm actually not doing it very diffrently...
I would get the file out. I'm in contact with Tony, i'll mention it.
dave
Old 11th June 2011, 08:48 PM   #14
Swifty is offline Swifty  Netherlands
dave
The chamfer I did is a full 45 degrees. What I will do is listen to them as they are now and decide from there if I will decrease the "cilinder". Thanks for the guidance!
Old 11th June 2011, 09:30 PM   #15
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Swifty, I hate to point this out at this point, but you have a severe grain conflict. Wood expands and contracts seasonally with humidity across the grain but not in length. Your sides are going to want to get taller, but your fronts and back won't. This movement can not be stopped. Hope for the best.........
http://www.evancotler.com
Old 11th June 2011, 09:57 PM   #16
Hi Evan,
I know :-)
I went for this construction because I just like the way this looks. I am not totally ignorant however, so I sealed the wood completely inside and out. Time will tell if that's enough...
Old 11th June 2011, 10:13 PM   #17
Swifty, I didn't mean to sound negative, but wood is my thing. Yes sealing the cabinet will help a lot and most likely the glue will allow the sides to creep up and down as they want to.
Old 13th June 2011, 09:41 AM   #18
Done! First impressions (listening to Kind Of Blue by Miles Davis): Very musical. The imaging is just so good! I cannot believe how complete the sound is. I am not missing a tweeter for instance. Lows are articulate and controlled. I will post updates on the sound as the speakers break in ut they sound better than the Tannoy D300 they replace already.
Old 13th June 2011, 12:56 PM   #19
Douglas Ingram is offline Douglas Ingram  Canada
Congratulations! And what a great choice for a first listen.
Expectation is the source of all misery; comparison the thief of joy.http://www.redrivercanoe.ca/
http://woodbecreative.blogspot.com/
Old 13th June 2011, 01:36 PM   #20
zman01 is online now zman01  Bangladesh
Looking great Swifty!
First build ever: Pensil 10.2 - in solid oakHide this!Advertise here!
Solid oak speakers??? tman204 Multi-Way 82 29th May 2014 03:29 PM
Steven's Alpair 10.2 Pensil Build Log StevenZ Planet 10 hifi 148 10th August 2013 02:43 AM
Pensil 10.2 build: Vent location? Swifty Planet 10 hifi 9 13th June 2011 06:01 PM
Copyright ©1999-2017 diyAudio
