#61 | |
Could you post your replies using a larger font size, I'm afraid I can't read it through all the smoke. ![]() Best Regards, Terry
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#63 |
very nice...love the trapazoidalness of it!
#64 |
Just stunning, Dave (Chris!!) love the veneer matching/colour.
![]() soundwise??- oh, Chris did you add a piece of material behind the front baffle cut-out to flush mount the driver, or use a thicker front baffle? best, don Last edited by doorman; 15th October 2011 at 07:16 PM. |
#65 |
The Mar-Ken12Ts are lovely... yes, and like Doorman, I'd like to know how they are soundwise.
![]() Here's the Mar-Ken 7.3 I finished recently. Very impressed with the sound. These are for a friend - I'm gonna miss these when he eventually takes them home. ![]() -Zia Last edited by zman01; 16th October 2011 at 02:34 AM. |
#66 | |
Thanks Don, sometimes the color and grain figuring just works with you, other times it's a struggle to finish the pattern for even a smaller enclosure than these with a single sheet. Yes, an additional 9mm BB plate (for total of 27mm) on the rear side of front baffle to allow sufficient core for fasteners.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#67 | |
nice work -
#68 |
#69 |
is it possible to get plans for any of the new trapezoidal Fonken? if not, will they be available in the future?
#70 |
frugal-phile(tm)
The boilerplate is here: planet10-hifi miniOnken Plan-Set Subscriptions
I am working thru the entire planset to do trapezoids for all (including the new FFxx5wk) -- there will be multiple variations for some of the smaller drivers. There will also be a family of WoofTs to go alomg with them all. This to emphasis our feeling that to get the best out of a FR, and to make it truly full-range, adding helper woofers makes the most sense. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Thread Tools | Search this Thread |
| First build - miniOnken | matherp | Full Range | 6 | 3rd January 2010 04:58 PM |
| Clear picture picture of KSS-273B | eledora | Digital Source | 0 | 27th October 2007 01:10 PM |
| MiniOnken FR125 (pic) | MCH | Full Range | 7 | 6th November 2005 03:40 PM |
| Wee Need A Picture gallery | jleaman | Everything Else | 11 | 7th March 2003 01:33 AM |
